Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lowered
Lowered
starting my drop project soon.......parts are on order
This is a discussion on starting my drop project soon.......parts are on order within the Lowered forums, part of the 4th Gen : 2009 - Present category!
so it looks like I'll be inspecting/tightening my Spohn control arms this weekend......I'll keep you guys posted with what I ...
Like Tree90Likes
Reply
Old 11-18-2016, 07:39 PM   #211 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
so it looks like I'll be inspecting/tightening my Spohn control arms this weekend......I'll keep you guys posted with what I find.......been driving like a grandma all week because I haven't had time to dive into it........more to follow
Sponsored Ad
Register to remove this ad.
__________________
2014 Charcoal RAM 1500 RCSB 5.7 8SPD 2WD
2016 White Suburban 1500 5.3 6SPD 2WD
A bunch of 73 Chevy C10 truck parts!
moregrip is offline   Reply With Quote
Old 11-20-2016, 07:35 PM   #212 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
So I was able to adjust the upper and lower Spohn control arms on the vehicle(did not remove them) with a $4.99 pin spanner wrench from Harbor Freight in the grinder section.
They all needed some level of adjustment, but the del-sphere's that needed the most adjustment were the rear lower Sphere's attached to the axle.
She's all good again, tight and quiet. Was not too bad at all on the adjustments, but of course I did not inspect them, just didn't have the time this weekend.
__________________
Old 01-10-2017, 08:06 AM   #213 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
so a little update, all is going well with the drop with the exception of the clunky Spohn control arm bushings. Using the Harbor Freight pin spanner wrench I am able to adjust the Del Sphere joints on the truck with the rear wheels off.
As many have experienced, they don't necessarily "stay in" adjustment very long, for me that equates to a few hundred miles before they start making noise again, but more importantly, as the joint gets loose and starts to move(cause of the noise) that probably isn't all that good for the joint itself.....but since it won't stay tight that's kinda how the joint lives it's life..........doesn't seem like an ideal situation, to me at least.
Also, and this one was surprising to me, as the Del Sphere joints loosen up I can feel my alignment being effected as I drive..........maybe I'm on crack here......but I can noticibly feel the truck driving differently(very slight pull), tighten the arms up, all is well.
I sent Spohn 2 emails through their online communication tool with no response.....probably a glitch....but who knows. I'll give it one more shot and see what happens. I'll post my findings. FWIW, Besides the noise/clunk I'm happy with the setup.
If I'm being 100% honest the clunkiness in the rear does have me not driving the truck as much as I like too.............which I suppose is good for my wallet but not really the intent of all these costly mods!
ok, that's about it for now. Working on a few tweaks and peaks to fine tune my setup, fingers crossed we get these joints figured out!
Wild one likes this.
__________________
Old 01-13-2017, 10:53 AM   #214 (permalink)
Ram Year: 2017
Engine: 5.7
Default Thank you very much
Just purchased a 2017 Ram 1500 Quad cab and was on the phone with Moe's Performance while I was still signing the paperwork. This thread has gave me pause before installing my 963SP kit. Thank you very much for the great write up and the time and effort put in to your posts. Is there a reason you didn't use the front/rear shocks that came with the kit?
DireRam is offline   Reply With Quote
Old 01-14-2017, 08:49 AM   #215 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Glad you got something from the detail! That's the whole point to these forums I think!
I went with the bilstein shocks because I believed they were/are more suited to the type of driving I wanted to try, some local autocross events from time to time.
Turns out, these shocks are pretty dang good in every situation, IMO......since I didn't go with the ready to run 4600 series, these 5125's took a little effort to fit up, but not much
If I were planning a drop again I'd wait to see how these brackets work out before doing so. Looks like there are some solid options out there now. I think these drop brackets, in theory, are awesome.........time will tell if they are roadworthy. fingers crossed!
__________________
Old 06-14-2017, 04:39 PM   #216 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Update: I ordered the Illicit no cut brackets, I couldn't take the clanking anymore! What a PITA those bars became.
For those that want a little more drop in the rear running the Belltech coils, how much did you cut for about an 1" more?
__________________
Old 06-14-2017, 07:50 PM   #217 (permalink)
Quicksilver337's Avatar
Ram Year: 2016 Ram R/T
Engine: Hemi 5.7
Default
Cut 1 full coil = 1" drop
moregrip likes this.
__________________
Go for it now. The future is promised to no one. ― Wayne W. Dyer
Quicksilver337 is offline   Reply With Quote
Old 06-15-2017, 12:26 AM   #218 (permalink)
Ram Year: 16
Engine: 345
Default
just read all 22 pages. very informative thread! cant believe I just now found this. I will be subscribing.
Walker345 is offline   Reply With Quote
Old 06-16-2017, 12:42 AM   #219 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Nice man, glad you found it a decent read!
__________________
Old 07-09-2017, 12:19 PM   #220 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
Illicit brackets showed up last week, going to get rid of the Spohn control arms and give the stock arms/illicit brackets a shot and see how that works out.
more to follow/will report back
On a side note: in back to back driving, I much prefer the ride/handling of my 2/4 lowered truck over stock.........MUCH more responsive and soild feeling.
I really wish the Spohn arms would have worked out, not just because they cost a good chunk of money but because I do like have the adjustability they provide. Unfortunately they are overly noisy and don't stay in adjustment very long......for those reasons I'm making the switch.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to remember the parts you order RockAuto RockAuto 1 05-18-2017 04:23 PM
Where to order Mcgaughys drop springs??? TwistedJake Lowered 4 12-07-2014 04:02 AM
Starting to buy parts. Need help! SATXram2013 Exterior 1 12-24-2013 10:54 AM
starting new project ljvsnyder General Discussions 10 03-13-2013 12:52 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
