I am so done with these Spohn arms. Can I go back to the stock arms with the 2/4 drop I have added or am I stuck with this set up? I am ordering Bilstein 4600's all around for a better ride. Any input would be great, Thanks.
Nope jsut run stock arms. Spohn arms are dog****, well documented at this point.
Im on air bags in the rear on stock arms, put a spohn panhard. Panhard works as intended
I contacted illicit customs and he gave me a promo code for us RamForum guys I don't think there is going to be a group buy.
I forgot to mention that I do have Spohn's adjustable panhard bar with the regular.Thanks, I am waiting for the group buy. I am hoping the adjustable panhard bar will fix the wheel issue.
After seeing all the issues with their Del-sphere joint I'm really glad it never bothered me enough to fork over the cash for the adjustable upper and lower links
So far from one install, axle brackets came off in pieces. So it likely wont be easy to go back to stock with the cut brackets IF thats an issue for you. I plan on using the NONE cut bracekts with my air system. It'll give me better angles and axle postion, maybe not bang on perfect, but better then it is currently.
My Truck with no air in system
Fulll air
Has ART kit[/QUOTE
I cut my brackets off in 1 piece,with a little bit of grinding they could be welded back on. You just need a little talent with a torch,and they're removable in one piece. I did weld the Illicit Cut Brackets on in a couple places,as I don't plan on getting rid of this truck for awhile,and when I do,i'll re-install the original housing with 3.21 gears. This housing has new 3.55's and a Tru Trac posi,so it won't go with the truck anyways when I go to sell it or trade it off.
Fulll air
Has ART kit[/QUOTE
Yah thats what the Sowardcustoms said to, hell swap rear ends. For me up in Canada i have much less availability then in the states for rear ends if i need a stock housing.
Still on the fence which route i'll take, what I do like about the Cut brackets is that it will get rid of the mount that bottoms out against my frame
Still on the fence which route i'll take, what I do like about the Cut brackets is that it will get rid of the mount that bottoms out against my frame[/QUOTE
I'm Alberta based ,kinda got an idea of what you're talking about,lol.
Soward I welded mine too,on the back side,and inside the front of the brackets where they butt up against the original front hole that the spacer goes in. More for piece of mind then anything,as I don't think they'll go anywhere with the bolts,but i'm a little like you OCD,lol
If you spot Dallas's posts on FB I've posted pics of mine on his threads,he's a good buddy of mine,so we combined pics.
