DwnDak
- Apr 5, 2014
- 170
- 80
- Ontario, Canada
- 2007
- Hemi 5.7
I've done a 2/4 with mine using the GF front coils and Belltech rears.. But I found once I put the airlift's in that only with 4-5psi in the bags it doesn't lift the truck enough to notice but it definitely cushions the blow on rough roads. I live in the country so I needed a 4x4 truck and wanted it lowered. It bottoms out on a few key area's enroute to my house, so I needed the airlifts. I've also towed 8k with it and had 800lbs in the box... They work as they should. I've considered the illicit no cut brackets, or the entire Inez 4-6 drop because I find I want more lowered!! However the 2019's are also in my wheelhouse... So I have to decide which way to go..
With a 4" rear drop get airlift 1000 kit..
With a 4" rear coil drop are you guys hitting the bump stops on rough roads/bumps? Did everyone cut them down or do you guys not hit them?
