thinking of going lower
SILVER_BULLET
ok i already have my truck lowered 2/4 but im thinking it could use a little more. i was thinking of getting drop spindles for the front to make it 4 inches in front but in the back im lost. what could i do to get 2 extra inches lower in the back and do you guys think itll have enough clearance without having to c-notch it. the only thing ive found so far is people cutting down the springs till its where they want it but im not sure how the ride would be affected and if that would cause some kind of safety issue or not?
WhiteExpress
Midland, TX
MOAR LOW! (sorry, it's the VW scene coming out in me)
That being said, I think you'll run out of upward travel on the control arm mounts here pretty quick. You going that low, might as well just bag the rear, shave all the factory mounts etc off the frame and do it all again.
trev
Mine already has a 2/5 on it, and I literally just dropped it off at my buddies shop to go lower. We removed the bump stops, I know it sounds ********, but they were already stopping it from going lower. We've already cut the rear springs so it's sittin at 2/7 now. I left to get ready for work and he's finishing the front to make it 3 or 4/7. I'll get ya a few pics when I get it back.
SILVER_BULLET
SILVER_BULLET
cool let me know how it rides and how are you getting the rear end back to center after lowering the back so much?
trev
Back to center? I don't guess I understand? Lol we've already done the rear, I had it at about 5 1/2 before and we cut the springs down to 7 and removed the bump stops. It's all good to go, just waiting on him to finish the front. I won't have pics tonight though, it'll be dark when I get off.
That's it before we started.
This is a truck down in Texas I'm tryin to compete with lol I'd like to sit that low.
SILVER_BULLET
SILVER_BULLET
The way the rear end is set up if you lower it it pushes it out towards the passenger side so it's not centered... And I think that truck was actually lowered a different way then what you did if it's the one I've talked to that guy c notched it and relocated where the spring sits on top to get it to lower more from the rear
trev
I actually just talked to him, he relocated a ton of stuff... Lol but my bed still sits in the center..
Update: I just talked to my buddy, he cut to much and the tires were in the fender wells, and couldn't turn lol good thing I have my old set of springs! I got them to him and he's fixing it tomorrow while I'm in school. I'll put it up at 2 and get some pics for ya!
trev
Alright after a bit of trial and error, I'm now running 4" in front and about 7.5" in the rear!
The ride quality is not to bad compared to stock, but I also like how lowered trucks ride. But as always, bumps are rougher!
Stangshcky12
Oshkosh, WI
5.9 Cummins
Because of the geometry of the rear suspension your rear axle is now sitting farther back and is off set to one side (crab walking)
To do this properly you should install adjustable control arms and an adjustable panhard bar/track bar
SILVER_BULLET
SILVER_BULLET
trev
I have the drop kit control arms. My bed is straight, I even asked my buddy if he checked it and he said the same thing.
As for the Clarence in the rear, I'd say probably 2 inches.
joeyoliver45
