using drop springs and drop spindles
delunad
Texas
ok guys as of right now i have a 2/4 springs and shocks have been changed out so i was thinking of getting the drop spindles to lower my truck some more i am running 305/45/22 ant thoughts on this thanks ahead of time
BlkRamRt
SoCal
HEMI 5.7
You are going to need a shorter tire. I was planning on doing the same a while back but I never made it happen maybe within the next few months I will pull the trigger and say f**k it... lol
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You will need shorter tires, adjustable control arms, adjustable panhard bar, and shorter front bump stops. These trucks look tough at 4/6, but its not as easy as just slapping some spindles on there.
charonblk07
Calgary, Ab
F1-A forged 349ci
If you just drop the front another 2" and keep the back end at 4" then you'll be alright with a shorter tire, but if you bring the back end down another 2" then you'll have to do a lot of reworking to do it properly. You CAN just drop it and leave it but you're going to wear out parts in a hurry. I'm down 4.5/6.5 running a 31.6"x9" tire and it still rubs on the upper control arm and swaybar endlinks.
delunad
delunad
Texas
As of right now I rub only when I turn all the way on he sway bar ................ so my tires are to big dam so with this size tire where will I be rubbing
delunad
delunad
Texas
Where can I get some adjustable control arms I got under my truck today and I see what you mean as of right now I have less then 1/4 inch before it hits but what kind of control arms should I get
delunad
delunad
Texas
Thanks
delunad
delunad
Texas
I'm looking for the front one or will I only need the back ones?
charonblk07
Calgary, Ab
F1-A forged 349ci
You only need the rears. The only time you'll want to swap the front control arms is if you are going down 4"+ in the front where you can start putting a lot more angle on the upper balljoint but even then it's not really required. I changed mine with a set from Michigan Metal Werks because I'm a 4wd and I have a lot more angle on my upper arms than the 2wd does.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Kurtis, do you know if MMW offers a drop spindle? I am doing coilovers in the rear right now, and need to lower my front at least another 2" to have the truck sitting the way I want. The problem is that I don't want to run the heavy McG spindles. Just curious if MMW makes a lighter 2" drop spindle.
charonblk07
Calgary, Ab
F1-A forged 349ci
They don't offer an off-the-shelf drop spindle but they can custom fabricate one if you want. I had talked to them about making a set of custom lower control arms so I could run a set of coilovers on the front but eventually other things started taking priority and the project fell through. There spindles would most likely be lighter than the cast steel McG's but it depends on how much plate they need to use to make everything, and they would need a spindle to jig from.
