Would stock shocks prevent going lower?
Perry
I have a 2016 Ram 1500 regular cab 5.7 Hemi. I've read all about people using stock shocks with their lowering kits/cut coils with no problems. Well tonight I cut my stock coils to get it level. I started with 1/2 a coil. Then another 1/2 coil. Then another 1/2 coil. By the time I stopped I've cut 3 full coils off. After the last 2 or so cuts, it doesn't seem to be dropping it any lower. Maybe the drop is so insignificant that I'm not noticing it? As the title suggests, could my stock shocks be preventing my truck from going any lower.
I know I can go out there and pull the lower shock bolt out to see if it would drop but I'm tired of fooling with it right now.
If I bought some bilsteins shocks, would it help make it drop another inch?
17CrewCab1500
3 coils should be like 6" of drop!!!!!
Perry
Perry
That's what I thought! 1" of coil is 2" of drop!
charonblk07
Calgary, Ab
F1-A forged 349ci
Easy way to find out is to pull the rear shock lower bolt and see where it sits when the full weight is on it. Another thing that can be holding it us is the suspension bushing binding, so loosen the rear control arm and panhard bar bolts and torque them back up at the new ride height.
Perry
Perry
I didn't think about the bushings binding, I'll try that when I get home this afternoon
Perry
Perry
So if anyone is wondering, I removed the lower shock bolt and let the truck down off the jack and it did not make the truck sit lower. So the stock shock will not prevent the truck from sitting low as it should.
Tray Burge
On the porch
Keep in mind its going to settle too, if you don't replace your stock shocks with performance shocks it's going to bottom out sometimes.
