2015 Ram EcoDiesel - Adding plow question
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Hey guys! Haven't been on for a while but have a question. My boss recently purchased a 2015 Ram EcoDiesel and wants to add a plow to it which he wants to lift the front suspension to handle the extra weight. The plow and bracket to mount it with weighs 400lbs. What should he use for the front suspension lift to handle the extra weight? I wanted to try to keep him away from the "Hockey puck" leveling kit but if that's what he needs, than that's what he needs. I didn't know if Bil's would work or not as well. Let me know what you guys come up with. I'd appreciate it!
Adam
Dantheman
South Carolina
1500s aren't really meant for plows but I think any leveling kit would work. If you're doing bilsteins then I'd set them at 2.8 because they're going to sag with an extra 400 lbs on the very front. Poly kits, like daystar and stuff, would probably cushion the ride a little since they have some give. But I would probably stay away from metal spacers.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
One issue I've heard of against snow plowing with the 1500 is if the truck has the BW 44-44 transfer case(if it has the "Auto 4X4" button). It can wreck the clutch that drives the front wheels, resulting in transfer case overheating warnings.
I think Timbren offers a front kit.
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Coil bag for front cost under 200 for the set gives1000 lb of lift
I would also like to see a link to these so I can forward them to my boss, sir.
The only plowing he is going to be doing is his personal driveway. It is a little long but he's not going to be using it constantly if that is any consolation. But I will be sure to let him know. Thank you!
Adam
14blackouthemi
North Jersey
I plowed with my 12 1500 crew cab sport. I used a western 7'6" midweight. All I had as far as front lift/level whatever you wanna call it was a 2in readylift spacer. Truck plowed awesome.
DannyMK2
Long Island, NY
2015 Power Wagon
not something i would be doing with that truck but timbrens are probably the best bet, with or without the leveling kit.
