2017 Ram 1500 Sport Rough Country 2.5" Installed
trikeffex
Hammond,La
2013 sport ram
Hey Guys,
Well ended up going with the Rough Country 2.5" Preload spacer kit to level my truck. Install went great even tho I hate messing with Strut Coil Compressors. My only complaint would be getting the top nut off the strut if you didn't have the proper tools lol. This was 1 of those times I'm glad I bought my Craftsmen Max Access Thru head Ratchet set so that I could put that on the nut, And the Smaller socket on a 1/4" drive Ratchet to prevent the strut rod from spinning. Other than the Rough Country Instructions having a lot of the wrong socket sizes listed, It wasn't bad! The ride is a little stiffer which I like so it turned out well for me. I installed the Rear 1" spacers as well but ended up taking them off as it looked nose heavy again. That was a waste of an hour lol!
Charles
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Looks good, do you have plans for larger tires ?
getting ready to do mine but will be running the stock tires for awhile.
trikeffex
trikeffex
Hammond,La
2013 sport ram
Yea I'm gonna get some different tires, But may just stick too 33x12.50's. I'd like to run 35's, But think it may look to stuffed in the wheel wells!
Charles
blkbaretta
TN
Looks good man - 33x12.50 would look good!
L84DNR
Fort Bragg NC
Are the pics you posted with or without the rear spacers in? Truck looks good bro.
quietpeen
2021 TRX
Hellcat
very nice. are those pics before or after alignment? and 34" tires will look great with your setup
LVnight1500
Charles
Are you planning on using the same rims? I have the same ones on my night edition. Just a little skeptic that 12.50's can fit on these rims.
mpicc84
North Eastern, PA
I run this kit too. It is a stiffer, less enjoyable ride. The lift puts the truck right where it should have been from the factory. I left my rear spacers on, but have debated taking them out to give my front end a higher look. I wasn't sure if it would be too much front end rake though.
trikeffex
trikeffex
Hammond,La
2013 sport ram
The pics are without the Rear spacers in. I believe I took some pics with them in, I'll post them for you!
Charles
trikeffex
trikeffex
Hammond,La
2013 sport ram
These were taken after the alignment. It def needed it as it had a good bit of positive camber after! Yea I was debating doing 34's!
Charles
trikeffex
trikeffex
Hammond,La
2013 sport ram
Yes I'm going to use the same wheels. They don't fit Great, But it will work lol.
Charles
trikeffex
trikeffex
Hammond,La
2013 sport ram
I didn't care for it with the Rear spacers. I kept them incase I have to tow something for a long distance, Then I can just throw them back in real quick. I actually liked the slightly stiffer ride, But then again I was use to my Powerstrokes ride!
Charles
mpicc84
North Eastern, PA
Charles
I had a leaky strut when I put this kit in, so I'm going to be swapping to Bilstein's instead. If I'm doing struts I guess I should just do them right. I do like this kit though.
I'm wondering if the Bilstein's at max will increase my height more then this kit did? Hm...
lone12star
Kyle, Tx
Do you have any pics with the spacers in?
mpicc84
North Eastern, PA
I can get some tomorrow, I don't have any offhand and its dark outside now. Stay tuned haha; send me a PM if I don't post them tomorrow, I may have gotten side tracked.
iHemiMan
Georgia
HEMI 5.7L
Fanta1500
Albany NY
Hey Guys,
Charles
Another orange ram on here sweet! Looks great!
