Dangulo
- Jan 26, 2017
- 241
- 108
- 2015
- 5.7
Im looking for a replacement UCA for my 2015 lifted 2wd 1500. Some companies list their upgraded replacements as 2wd/4wd. Are they the same part# ?
Why are you looking for a replacement?
I would recommend getting the zones as they have a better angle than the factory.
Hoping I can revive this thread b/c I had the same question for slightly different reasons. I have a 2017 1500 2WD and would like to level it with the Max Trac front lift springs. Problem is that it is common for the UCA to smack the coil bucket, which I'd like to avoid. This seems to be a slightly different issue than the ball joints coming out of the UCAs as experienced on the 2013-14 4WD trucks. Anyways, CST and Max Trac (coming soon) sell UCAs that will supposedly provide more travel but the costs is north of $700 which makes for a pretty expensive level. Plenty more "4WD" aftermarket UCAs that I'd like to use if they solve the problem (looking at you ReadyLift). If I'm reading it correctly, it appears the OEM UCA part numbers for the 2 and 4WD trucks are the same (68227900AB / 01AB) so I'm wondering why I can't use the 4WD UCAs on my 2WD 1500.
Anyone done it or otherwise found a solution to the coil bucket contact on 2WD level kits?
