3" PA body lift
Mbarclay
Canton NY
I want to buy the body lift anyone know for sure if they fit 13+?
Rough country sells them for $130 less than pa with the same part number. But rough country says they only fit 09-12 because the bolts were changed. On pa's site it says the kit fits 09-16. It's worth buying through rough country if it's the same kit when I'll save $130.
jonathanhudaon
Go with PA, I have one on my 13 ram. It fit perfectly, from what I know Rough Country's don't fit the newer trucks (plus anything RC makes is junk)
Mbarclay
Mbarclay
Canton NY
The rough country is a pa with the same part number just $130 less. Just trying to figure out why they say it doesn't fit 13+ When pa says it does
jonathanhudaon
Are you sure of that?
Mbarclay
Mbarclay
Canton NY
Here's a screen shot of rough country's website. Same 60203 part number as pa's website
Here's a screen shot of rough country's website. Same 60203 part number as pa's website and the picture says performance accessories correct me if I'm wrong
xrsman
Ontario
3.0 Ecodiesel
My advice is to call PA and ask them to match the price
Klaus96
Illinois
2014 2500 CC Laramie 4x4
60203 is the one I put on my 14
I bought it from Amazon and selected "gift wrap" option and filled out the card as if my wife gave it to me...lol
Klaus96
Illinois
OP...did you ever get the kit?
Klaus96
Illinois
I don't know about him but I bought it and am having trouble finding a shop willing to install it
I did my own install and it was pretty easy. One key note is when removing the steering coupler to install the extension, you need to COMPLETELY remove the set screws, not just loosen them. Other than that it wasn't too bad.
I laid out all of the parts and went through the instructions to make sure I had everything (was missing some bolts) ,called customer service and they sent them out right away.
Next I went through the instructions and found all of the locations called out in the instructions.
xrsman
Ontario
3.0 Ecodiesel
Why's that? It's easier than installing a suspension lift
pitajr
Niagara Region Ontario
One shop was just being ***** because they usually lose money with me I think. Booked an alignment, they couldn't do it because of the bead protector on the tire, had to mount my stock rims and tires on and bring it back another day. Other thing was balancing the new tires, they spent over two hours and i later found out they couldn't get it because there were balancing beads in it. Had to remove them and re-balance from scratch.
Other shop that specializes in that stuff is saying because I didn;t buy from them, they won't install.
