4" or 6" lifts with 35x12.5 R17's
Shane1990
He I 5.7
Just got it finished this morning
Ferro
I have a 4" lift with 35s and Bilsteins set at 1.4. People think it's a 6 inch lift. And I can barely get in the garage.
WilliamS
Tampa FL
4" lift with bils at 1.4 is pretty close to a 6inch lift.
wester425
south east Texas
35x12.50x20's.
I just purchased this truck and it was set up already. Can you guess tell me what size lift it has? It also has a slight lean to the back, what would I need to do to level it out?
mpittman
mpittman
Indiana
2015 Big Horn Crew Cab
If your rear is lower than the front, you have two options. You can add a 3/4" or 1" spacer to the rear, that would be the easiest.
Or, look at the front struts and see if they are Bilstein. If they are, you could disassemble the front struts and adjust the Bilsteins down one setting. That should get you level. The second option is a lot more work, but if you can do it yourself, its free :)
Will Ram 2500
Kansas City, MO
Doesn't any adjustment to the Bilstein require an alignment afterwards?
mpittman
mpittman
Indiana
Probably wouldn't hurt, but only going down one setting, I wouldn't think would throw it off that much.
SuthrnRAM
Jax Beach, FL
That's perfect looking! As I've been thinking of doing a 6in lift on my truck now that I've had it leveled for a couple years thinking the 18s might look better than the 20s, 17s just a tad too small imo. I was always a big fan of 18s on 35s and 20s on 37s personally. If you get an 18x10 wheel it would look even deeper! I think fuel hostage also makes an 18x12 wheel not sure for the ram tho.
Freed127
Tamaqua PA
Ya id like to swap my wheels this summer. Either an 18x10 or go to a -12 from my 0 offset 9 wides. I want more lip but am trying to avoid flares
