4" Superlift test drive-new ?'s
Coop427
In Sane
14 Ram 1500 Sport
I just installed a 4" Superlift w/ Bilsteins on my 2014 1500 and drove it about 1.5 miles to the shop for 35's & alignment. It drove terrible and the front end felt like it was on a cloud. Also, the "Stability Control" indicator came on. I know it being out of alignment will cause it to be rough, but will that make the steering "jump" sideways or make the truck wander? I'm guessing the indicator came on because the wheels were turning at different rates on corners? Any advice will help me sleep better, thanks!
Jershipe
Monroe Michigan
Could just be way out of alignment. I did rough country lift. Wandered a little. But I measured and tried to get it close when I reassembled it. I wouldn't worry.
WilliamS
Tampa FL
when i did my 3 inch level, i drove it 1 day without an alignment and needless to say it was brave of me at highway speeds. Get a proper alignment itll work out.
the radical change is now your front tires are on their tip toes from the camber and toe so its less stable and fighting itself.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Of course it will wander and jump around without having the front end alignment done. If nothing is straight or is fighting each other from side to side it's not going to drive very nice.
Stability control may have been kicked on because of this but I'd also double check that all the wheel speed sensors (mainly the front ones) were installed correctly.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Thanks for the replies, I was nervous and racking my brain if something I'd forgotten made it drive that bad. After the alignment & 35's, it drives incredible! Thanks for all the advice on here. Better pics later, raining & temps dropping below freezing.
picture.php
Ferro
What are your measurements from the ground to the lip of the fender.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Before the lift, front was 36" & 36.5"
Rear was 38.5" & 39"
With Toyo AT II's & the Bilsteins set at 1.4, the front is 42.5" & 43"
Rear is 43" & 43.5"
So overall it lifted the front about 6" and the rear 4".
Ferro
I have the same set up you do. My Measurements are the same as yours
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Cool! Guess it works. I'm thinking 3/4" spacer in the rear down the road.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
I have the Superlift coils, I believe thats the same thing, but I'm thinking adding a spacer since the Bils would allow it.
