4th gen HBS level kit
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I should have said strut - not shock. There is no difference in the movement on it.
JasonK9
Did you take it to get aligned and they said it was good?
I haven't taken it to any place to have it checked. There isn't anyone that will give you a free estimate on that around where I'm at.
The steering wheel is perfectly straight and it doesn't pull left or right even a tad. Every oil change I have the tires rotated so I'm just going to keep an eye on the tread.
My last Chevy, I put a rough country 2.5 strut spacer and had no issues so I'm hoping for the same.
quietpeen
2021 TRX
Hellcat
to lift the front end like that you changed the geometry, its your call, but i would get it aligned and not assume its good. New tires are a hell of a lot more expensive than an alignment.....lol
ADDCJ
cummins
any pics of the truck from the OP?
srqFF
Sarasota FL
Looks good. Now if only I can find a company that makes a kit for 2WD.
