6" lift plan to run 37's what do I need to know.
Bighorn1217
So I just joined here and searched a bit. I own a 2011 ram 1500 crew cab I plan on doing a 6 inch rough country lift and want to run 37x13.5 tires. I found a set that come with xd wheels that measure: 17x9 with a -24 offset and a 4.06 back spacing. I have read up on the whole spacer thing but have yet to find a solid answer if these 37's will fit with a 6 inch lift, and if the back spacing and offset is okay. I don't mind the wheels sticking out of the fender I'm actually trying to go for a wider stance. If these fit what size spacers will I need (front and back) and if they won't fit what will fit. Thanks guys
White Beauty
Moncton, NB
2011 Ram 1500 SLT
What gears does your truck have? this will play a big factor in the performance of your rig after the lift.
Maxtrac Suspension
Anaheim, CA
4.7L V8
Quick question for ya.. is your truck a 2wd or 4wd?
omaha123
Nebraska
5.9l CTD
13.50s with -24 mm offset will be close.
Someone should have a definite answer for you soon.
May have to add bilsteins
Sent from my SCH-I545 using Tapatalk
War Machine
Probably going to rub. I'd say you'll need the 6" plus Bilsteins at 2.1" and probably still need to do some trimming on the front bumper
mattman_13
Find the actual measurement of the tires somewhere. Especially on that width of tire on the width of rims.
I do suggest bils while you are in there.
B
Bighorn1217
My gears I believe are 3.55 gears. I will check later. It is a 4wd. I was trying to look online at the bilstein. But every time they say that there isn't any that will fit my truck. What is a good offset and back spacing to look for then?
War Machine
I fit 38x13.50s with 6" RCX, 2.1" Bilsteins and a 1.5" body lift on 20x10 -12 5" BS
B
Bighorn1217
I'm trying to avoid a body lift. So say I do the 6 inch lift and 5100 bilsteins all around, or do I only need them upfront? What size wheel and back spacing and offset should I be looking for?
Bully's Performance
RCX up front + Bilsteins up front set to 2.1 + 1" Rear coil spacer to avoid the Cali Lean, the max I would run would be 37x13.50's on the tire, and many of our customers have gone with 20x10 -24MM and been just fine, a few have had to do very minor trimming to avoid minor rub at full lock.
The front Suspension does not handle anything much bigger than a 37" tire very well so I would not go any bigger than that.
As far as the performance hit you will notice with 3.55's it takes a bit longer to get up to speed and will feel kind of slugish, generally if you have 3.55's we do not recommend bigger than 35's unless you plan on doing gears.
If you would like to discuss pricing on parts, and other options feel free to email us at [email protected], PM us or post in our Vendor section here on the boards, or call us toll free at 855-432-FAST we would be more than happy to chat with you and assist you in any way we can.
Thanks
Jeremiah
B
Bighorn1217
okay so after reading A LOT of builds and reviews. i want to know if this is possible.
5100's set to the max 2.8
3 inch pa body lift
and then a 1-2 inch rear spacer.
37x13.5 with a -24 offset.
i know with this i will have to buy longer break hoses but i cant seem to find them online anywhere for that big of a lift.
before i order all these parts i want to make sure this build will work fine with cv angles. i know people have run a 6 inch and 5100's maxed and have no issues so adding a 3 inch pa body lift wont effect the angles at all since the only thing being raised i the body. like i said i want to double and triple check on here that this set up will work, before ordering everything.
VolsRam
Franklin, TN
HEMI 5.7
There are people that fit 35s on a level with no issues, so I would guess just 2 more inches of tire wouldn't be a problem with 4 more inches of lift. Also, with your wheel question, the offset and backspacing shouldn't be a problem.
VolsRam
Franklin, TN
HEMI 5.7
I'm also making plans to do a 6" with 37x13.50x20 with a 20x10 wheel and -24offset wheels. But my wheels will be about a 4.5" backspacing. I will also be planning to regear to either 4:10 or 4:56 to recoup some power and performance.
B
Bighorn1217
sweet. so 6 inch suspension lift, 3 inch body lift, 5100's maxed out upfront 2 inch spacer in the rear and then obviously longer brake hoses and ill be all set?
VolsRam
Franklin, TN
HEMI 5.7
Yes, you'll definitely be good with all that. You could probably go 38s with that. Just make sure to get gap guards with the BL, and be careful about maxing out the bilsteins. I've heard of people having trouble with them maxed out, but no issues at 2.1.
B
Bighorn1217
what kind of issue at maxed out? just like the angle of the cv axles? if i go wit 2.1 then i probably wont need rear spacers? or with the lift and bilsteins should i just order a 1 inch rear spacer to be safe?
VolsRam
Franklin, TN
HEMI 5.7
I have not done a bunch of research for a lift yet because I know it won't come for a few years, so I don't know about the spacers. I know some 6" kits come with a 6" front and 3" rear, or you can do 6" front and 5" rear. Almost like it's keeping the rake in lifting. So with that in mind you may not need a spacer period. But one thing you can do is check the rake you have now by checking the height from ground to bottom of fender on all 4 wheels. Then add together the lift height for front and rear and determine what you're looking for.
As for Bilsteins, I've read of a lot of wobble issues and wear when going to 2.8. I can't remember all the issues and suggestions, but if you do a search for bilstein 2.8 you should be able to find a lot of threads about ride quality.
B
Bighorn1217
alright cool ill keep that in mind. hopefully there will be a build thread for my truck soon!
VolsRam
Franklin, TN
HEMI 5.7
Alright, I don't know if you have been searching any, but I went back and looked at some old threads about Bilstein 5100s. There are people that have set them at 2.8 with no issues, but others have posted about wobble while driving in 4 wheel drive. Also, other have seen ball joints wearing prematurely when setting at 2.8. But they mention that new control arms will take care of that. I don't know if that means you can run 2.8 with a lift and see no issues, or if they're saying they went with a lift kits and got rid of the bilsteins. Hope some of this helps.
