Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lifted
Sponsored Ads
Register to remove these ads.
Lifted
alignment good .. but tire wear uneven?
This is a discussion on alignment good .. but tire wear uneven? within the Lifted forums, part of the 4th Gen : 2009 - Present category!
Register to remove these ads. It's free! to start off. Hi! I'm new to the truck world. i have a ...
Reply
Old 02-01-2012, 08:41 AM   #1 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Default alignment good .. but tire wear uneven?
i have a 2010 1500 QC with a hemi. It has a lift on it and roughly 34.5s (damn metric tires)
i've noticed significant wear on the front tires. Only the inner half is rapidly wearing. it's the same amount on both front tires. i brought the truck in for an alignment and they said that it was perfect. so what's wrong? and how do i fix this?
i assume that once the wear is significant, it isn't really fixable for the current set of tires. but i really don't want this to happen again with a new set of tires! tires had maybe half an inch of tread and used up 1/4in in 6000 miles on the inner half. the outer half is still sitting pretty at 1/2in of tread.
by chance, is there a way to fix the problem with the current tires?
minileprechaun is offline   Reply With Quote
Old 02-01-2012, 09:29 AM   #2 (permalink)
Senomar_Dtk's Avatar
Ram Year: 2007
Engine: 4.7
Default
That really sounds like an alignment issue and I would have thought negative camber. Maybe check your ball joints and tie rods to see if they could be worn out and maybe causing the issue.
__________________
2007 Ram 1500 4x4 Quad TRX4 4.7L
I have a few mods.....more in the future
Senomar_Dtk is offline   Reply With Quote
Old 02-01-2012, 01:20 PM   #3 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Default
yea .. i thought it was an alignment issue too. there are no weird vibrations when driving down the highway. vehicle accelerates and brakes straight.
do lifted rams have different alignment specs from stock?
what do worn ball joints and tie rods look like?
either way, is it likely to have them worn the same amount on both sides? because the tires have identical wear for driver and passenger sides.
Old 02-01-2012, 02:37 PM   #4 (permalink)
Hollabakzach23's Avatar
Ram Year: 1998
Engine: 5.2
Default
I believe if you jack the front of the truck up and put one hand on the top of your tire and one hand on the bottom of your tire and rock it up and down to test your ball joints. If there is a lot of wiggle room then its time for new ball joints.
Tie rods would be the same procedure only with hands on the left and right sides of the tires.
Hollabakzach23 is offline   Reply With Quote
Old 02-01-2012, 05:08 PM   #5 (permalink)
TexasRammer's Avatar
Ram Year: 2002
Engine: 4.7
Default
did you buy the truck new or used? did you put the lift on it?
__________________
TexasRammer is online now   Reply With Quote
Old 02-02-2012, 10:15 AM   #6 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Default
bought it used. with 8k miles on it. the lift came with the truck. lift is all mopar parts. i'm pretty sure it was installed at the dealership when the first owner purchased the truck new.
could the dealership that checked my alignment just suck?
Old 02-02-2012, 01:12 PM   #7 (permalink)
quietpeen's Avatar
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
Send a message via AIM to quietpeen Send a message via Yahoo to quietpeen
Default
i would def. try a different place for the alignment. Something in the front end is out of spec
__________________
RamForum.com Moderator
quietpeen is online now   Reply With Quote
Old 02-02-2012, 01:47 PM   #8 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
Deff get another shop to check it
__________________
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Old 02-02-2012, 02:23 PM   #9 (permalink)
Ram Year: 2010
Engine: Hemi 5.7
Default
yea. i'm an idiot for not having someone else check it when i knew something was wrong down there. i'll get on that.
for my own knowledge....
lifted trucks have the same alignment as stock trucks right?
does anyone know where i'd find stock alignment specs? maybe something i can compare with the new alignment so i can feel better about the job.
Old 02-02-2012, 02:28 PM   #10 (permalink)
3rd Gen / Site Mod
Engine: 5.7 / 5.7
Default
Get the shop to give you the print out of the specs, they will have to stock spec on there along with how far yours is out. Make sure you take it to a shop that knows about lifted trucks and a laser adjustment instead of the old school mirror and light setup.
__________________
Reply
Bookmarks
Tags
alignment info, lifted alignment issue, ram allignment problem, tire wear, wear problems
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Alignment Krypt0n0tic Lowered 17 02-16-2012 04:26 PM
Bilstein = alignment? Nine5Three Lifted 7 01-04-2012 07:29 PM
Alignment issues....HELP!!! BKNBK Lowered 6 08-08-2011 02:19 AM
Lowered 4wd alignment RubberFrog Lowered 37 01-08-2011 12:16 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
