Am I leveled?
Dryates
Texas
I'm pretty sure there is no level kit on this truck, I can't see any kit when looking up the front coils. I have 1 1/2 inch rake 2014 1500 4x4. Front measure 38 1/4 and rear is 39 1/2.
daveray9
Bilsteins on there?
Dryates
Dryates
Texas
Factory shocks in front
dan1911
Fairbanks, Alaska
Must have spacers or something. Assuming you got it used but it definitely didn't come from factory like that (although I wish they did!)
Sent via telepathy
Eline24lenny
2o12
5.7L
There's definitely some kind of leveling kit on there
Sent from my SAMSUNG-SGH-I337 using Tapatalk
RandyGallup
The front kit is hard to see when installed. I had the same question when I got mine and had to touch the top of the spring to realize it had a leveling kit on it.
Robocop_9
West Virginia
Definitely leveled. Mine measured
Before
Front 36
Rear 38 1/2
After
Front 39 3/4
Rear 40 1/2
Dryates
Dryates
Texas
Does the top of the front shocks site directly on the metal inside the upper "cup" or is there a small something that fits in between? The rears definitely do not have any spacers, but the fronts I'm not 100 % positive, it doesn't look like any spacers I've seen. and really doesn't even look like a spacer, but i could be wrong
Dryates
Dryates
Texas
These are the best pics I could get what do you think, the pic on right shows best what i was referring to, looks like it has some kind of groove that the studs would fit through but in person it doesn't appear to be metal, but im not 100% sure, and i can't find any leveling spacers online that look similar
trikeffex
Hammond,La
2013 sport ram
Could be the Daystar comfortride Leveling kit. Their kits are Poly! It's def leveled tho!
Dryates
Dryates
Texas
Looked again this morning, and I guess it has spacers, fabtech i believe, suppose I'll swap for bilsteins, any guess how much difference I could expect at 2.8 with 1 inch rear spacer
R.L.K.
Bristol , Tn.
Probably will raise the front about an inch +/- .250"
I'd install the bils then drive it around a bit for them to settle , get an alignment then decide on the rear coil spacer that you need .
You may not want a spacer at all , or maybe you'll decide on a 3/4" spacer ...
