the zone upper control arms provide no lift. they are just a stronger solution to the rams that had the ball joint issue. I saw now lift from mine. you can add the zone 1.5" body lift with the bilsitein 5100 front leveling struts but you can not add the strut spacer on top. sounds like what would work best for you is the 5100's up front and the zone 1.5" body lift. add the UCA's if you think your truck might have ball joint issues. I got mine just to be safe.
Can you explain this kit then. It is the zone 3.5 without the 1.5 body lift.
