BDS 4" or 6" and park in my garage at 83" high
Soulsickness
2017 RCSB
Hello All,
I'm ordering my 4" or 6" BDS lift in the next day or two. I'm wondering if my truck will still fit in my garage if I get the BDS 6" kit.
Measurements with full tank of fuel and top of the truck is 76". My garage measures out at 83". I would also like to run 20x10 with -12 offset wheels and Toyo 35/12.5R20 R/T tires if possible.
Fenders tallest measurements taken:
Front 37 1/8"
Rear 39 1/2"
Also what brand/length braided brake lines for the front should I order with each of the following lift kits?
Thanks
Solid State
2011 Bighorn
I have the zone 6/5 kit with bils set @ 2.1 and I clear the weather strip on my 7 ft garage door by a little over half an inch. 2011 CC
Las Vegas NV
I have a 2016 1500 sport CC with a 6' BDS lift on 13.5x37 toyo R/T tires.It needs 85.5" to clear the sat antenna on the roof.
Witch
Hemi 5.7 liter
Assuming you have 33's and go with a 4" lift it will add around 6" from where you are right now
That is close
S
Soulsickness
2017 RCSB
How much does the antenna add from the roof lines highest point? On my 2017 Ram wised up and my slim antenna is not the highest point on my roof line.
Thanks for the feed back thus far everyone!
Shady
Cummins
Do you have enough room to enlarge/raise the garage door?
Sent from my iPad using Tapatalk Pro
muddy12
Indiana
Also keep in mind that the angle of your garage approach can have a big effect on weather or not you fit through the door.
I've got 6" RCX and 35's on a 2012 CC, and by tape measure alone, I should only clear my 7' garage door by just over 1/2". However, there is a depression in my garage floor, where the door comes down, and the slab in front of the garage is about 1" lower than that. This allows the truck to enter with about 2" of clearance between the roof and the door weather strip.
S
Soulsickness
2017 RCSB
My driveway is at an upward slope but I do not recall if the 2' concrete slap before the poured garage floor is lower or not. I do how ever plan on keeping the rake on the truck with the BDS 6"/5" rear coils.
The 83" measurement is to the center of the weather striping.
firemedic10584
Central Fl
I don't fit in my 7' garage with my 2016 Ram 1500 with a Zone 4" / 3" lift, bils at 1.4 and 35" Toyo RTs on...my shark fin antenna on top would hit...like others have said it's almost specific to your garage and how the angles and slab is..
muddy12
Indiana
........my shark fin antenna on top would hit.........
I forgot all about the antenna. I bought my truck used, with the lift already on it. I don't have the "shark fin", but my first mod was to swap out the factory radio antenna for a short one. The factory one did not clear the garage door opening, and rubbed on the raised door while pulling in/out.
6.7CumminsDrvr
The Dude abides………
Georgia
My 4" lift w/Bils @ .7" on tires that spec out height wize to what most 35's do (34.5") and my truck fit in my garage. IIRC, I measured about 83" of usable height and my shark fin just slides under. Well I had a pic but I guess it's too big to load..........I've posted it before
Solid State
2011 Bighorn
Set something 7" high on top of your truck, and drive in and out of your garage. If it tips over, you won't fit. All there is to it folks!
mpittman
Indiana
2015 Big Horn Crew Cab
My garage door is 83". I got a 4" BDS with 3" rear coil springs and Bilsteins up front at 1.4". I have 35" tires. I barely squeak under with my shark fin. My fenders are 43.5" in all four corners. Totally level. ec611dc437d07db45ede069d7439d7f0.jpg
WiSH2oo0
MN
2017 1500 Express 4wd RCSB
Don't take those tires out of the back while parked in the garage, you may never get back out :favorites13:
mpittman
Indiana
Lol. They're out and she still clears, barely.
joeygster
Ancaster, Ontario
The opening on my garage is 82 3/4" because of the weatherstripping on the bottom of the door. I've hiked my door limit up with the garage door opener as far as I can go to get that 82 3/4".
My truck gets in with room to spare with the 4" Superlift, no Bilstein 5100's (so I've still got a bit of a rake), & 35's.
I have the puck Navigation antenna instead of the sharkfin....apparently it's a Canadian thing. The puck sits far lower.
http://www.ramforum.com/f40/4_lift_35s_-_overall_height_re_fitting_garage-76379/
http://www.ramforum.com/1319683-post36.html
You should have no trouble with the 4" lift getting in the garage with 83" of height.
If you've got no sharkfin antenna, I'd hazard to guess you could probably even get in with the 6' lift.
S
Soulsickness
2017 RCSB
Thanks for all the help thus far everyone :rocking:
I just stacked two cartons of smoke on there sides which came to 7". I then proceeded to drive back and forth a couple times in and out of the garage.
It looks like 7" is right at the bottom of the weather stripping anything higher would most definitely hit the weather stripping. From my math it looks like a BDS 4" is in my near future.
mpittman
Indiana
Do you have a shark fin antenna? If so, don't forget to account for that. Also, are you changing tires? Stock tires are 33". If you put 35"s on, your cab raises another 1 inch.
S
Soulsickness
2017 RCSB
No shark fin antenna and I would like to run 20x10 with -12 offset wheels and Toyo 35/12.5R20 R/T tires. My stock tires are 275x60R20.
RedFlameRam
