- Dec 1, 2013
- 12,803
- 12,500
- Bristol , Tn.
- 2014 4X4 QC Express 6 speed auto 355 differentials
- 5.7 Hemi
Still on the fence between BDS AND ZONE and now RC
There's a couple diff options for 6 " kits from BDS if I remember correctly, one does come standard with the adjustable Fox coil overs and 5" rear coils , among other options , one being a preload spacer up front utilizing your oem front coils and 3" rear coils .So this might have been brought up but my question is doesn't bds come with fox shock coilovers standard with the 6in where zone you have to add them to the base lift? From what I say on both websites it almost equaled the same price but bds atleast came with them for around $4k
I think the stiff ride from the BDS kit has a lot to do with the rear Fox shocks. They are extremely stiff, so I think I'm going to be getting rid of mine. I havent decided on which shock to replace it with yet, but the Fox rear shocks will be coming off. They are almost impossible to compress by hand while on the truck which is overkill for how I use the truck.
http://www.ramforum.com/f40/installed_bds_6_lift_fox_2_0_shocks_way_soft-98777/
these members say the FOX is too soft
I could not compress the shocks by hand to put the lower shock bolts back in. I'm 6'2" 215lbs, and struggled with this. That is way too stiff on the compression for a truck that gets driven mostly on the street.
