Bent front control arm?
PCT
2019 2500 6.4
Northern California
Btw the way, i would check the oil pan.... looks like your leaking quite abit... Could be just the picture but looks leaky
K
k1ng87
def getting it fixed....the truck is only a year old and is still worth about $34k
gassersarentdead
ohio
they're going to replace the entire frame as you can't get just the crossmember. Also replace the cross member and the some power steering componenets as the power steering motor was cracked as well. All in all, about $6k to fix and and about 3 weeks.
6k? It should be more than that. I had 2 quarter panels replaced, one door, and front bumper,and one tire/wheel. Parts and labor was like $6800 for that. It only took like 3 days. 3 weeks of labor costs and parts has to be more.
K
k1ng87
well...not 3 weeks of labor...most of that time is just getting the parts in...once its all in, they can get it done in about a week...
gassersarentdead
ohio
I guess i just thought a new frame and everything else would be a bit higher.
Avurado
