Big lift
Thatdude596
buckeyes state
2009 ram big horn
here's a true 11" of total lift on my 09 with 37s...wish i went 40s but didn't plan on lifting it this high.
gassersarentdead
ohio
I just have a 6" and bilsteins maxed. Not a 4th gen, but I went and test drive this 04 cummins today and my truck looked like a little ***** beside it.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
That's because any car or truck next to Cummins is a little *****.
Sent From FBI Surveillance Van 29
Ignitionorange15
Manitoba
Sas
Sounds like it's solid axle swap if you want bigger lifts. Never done one on the Rams, but they sure open new worlds on the 88-98 obs gm trucks
jstacey8
hiram maine
Are we talking half ton or 3/4 and 1 ton? Of your talking about 3/4 or 1 ton go on Instagram and search megacab40s it's the biggest lift I've ever seen on a ram
xrsman
Ontario
3.0 Ecodiesel
And how do I do that? Without lowering the back to match the front? Would the rancho quick lifts accomplish leveling the truck even though it already had a lift?
Bilsteins would do it
Sent from my SM-G920W8 using Tapatalk
Thatdude596
buckeyes state
2009 ram big horn
blue beast...5100s up front, just make sure u take off preload spacers and buy a 1-1.5" rear tgc rear coil spring spacer
Gaboy6131
Here is my 2011 with a 6" lift and 2" level on 37s.
