BigRed4x4
- Apr 24, 2015
- 590
- 235
- Mid Michigan
- 2014
- Hemi 5.7
Well , your spring seat is correct and you are set @ +2.1" .
Washer may be in the wrong location and the top nut likely isn't torqued properly ?
This usually causes the a rough or a bump in the ride .
How much rake did you have prior to the bils install ?
Some trucks have less than others ..
It was totally stock prior to the bil's install, I never measured.
