Machete
- Oct 24, 2015
- 132
- 32
- 2019
- Hemi 5.7
Figured I'd tackle this install with some decent weather finally showing up. Not off to the best start. I noticed I only have one spring clip. This is after I have the first side completely apart. I just have a few questions.
All my questions are regarding the installation of the Bilsteins into the spring..
1) I guess the spring has to be compressed more to fit the higher settings compared to the stock?
2) Is it vital that I keep that black plastic housing that goes inside the springs?! It won t stay in place and keeps sliding down. I assume it s just to keep debris out..
3) I read a member recommends the washer doesn't contact the nut and sits at the top of the piston?
4) Is anyone not using a torque wrench? Should the top nut be to a certain spec before releasing the spring compressors. .
Thanks
Thanks
