Bilsteins with 1.25" RCX
CoalRegion08
What do you guys think of the Bilsteins set at max 2.8 with the 1.25" Rough Country body lift? I want to put 35s on. Will I need any wheel spacers (1/4")?? I have a 2012 big horn quad cab.
Any help/guidance would be appreciated. Photos would definitely help. Thanks
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Thats a nice set-up for your truck for sure!! :rocking: When you order the bodylift from Rough Country make sure you get the wheel spacers. your gonna need them to run 35's on stock wheels. Post pics when your done!
TXKID
Houston, TX
You might want to get a rear leveling kit too. Depending on your stock rake, the bilsteins at 2.8 might make the front end higher, but you might also like the west coast rake look so its up to you.
DisturbedGator
I have that setup, had to add a rear spacer to make it level tho
C
CoalRegion08
DisturbedGator, your truck looks great. Do you have 35" tires on? They don't look stuffed from a side view, right?
DisturbedGator
C
CoalRegion08
Looks good. Thanks
How was putting the 1.25" body lift on?
DisturbedGator
install was a pia, but i did it by myself. nothing you cant do in a garage with hand tools drill bits and a cutoff wheel. also get a jack that goes high
