Bilsteins, Icon Upper Arms, and 3/4" Rear Spacer Installed
novelmike
Central California
Is your truck a 4x4 or 2wd?
I cannot tell if the spindles are hiding the CV's or if they're not there.
Coop427
In Sane
14 Ram 1500 Sport
Where'd you get the 3/4" rear spacer. I can only find 1" and want to add it to my 3" rear coils & 4" lift. Thanks.
freefallin
Look into this before purchase, not sure if you should add spacers to any coil besides the OEM.
Ram Man
FL
2013 Sport
That color is awesome. With the blue/black theme going on, in my opinion, your fogs are the only thing that stick out. Maybe a light tint over them or even a custom black housing/projector setup.
Either way truck looks bad ass
PassivAggressor
I believe he has UCA's because he got a stage 5 Icon kit, which comes with them anyway. They may just have shipped separately and came in early.
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I didnt want to install the Bilsteins without the upper control arms because of all the guys who have had the ball joint pop out of the factory arms with the front leveling kit. Icon went ahead and shipped the control arms to me first so that I can run them while i wait on the coilovers and shocks to be built.
Andrew09HEMI
Looks awesome and glad I can see this wheel/tire set up! I was going to order NV's but they're on national back order 4-8 weeks, so my next choice were the Grids/Mesh. Loving the beefy stance that fills the wheel well.
Gary2
S Jersey
The way the thread started out I thought we had another option for replacement control arms but the longer I read it sounds more like they are part of a new kit . Are these available as just control arms?
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You can purchase the control arms separate as well...
http://iconvehicledynamics.com/shop/289-2009-up-dodge-ram-1500-uniball-upper-control-arm-kit.html
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
what are you doing with the ground force, first dibs haha
I have a local that is supposed to pick it up Friday. If he falls through, I'll post it up here.
SilverSurfer15
Im curious why you went with the uniballs over BJ? I cant remember if that was discussed in the other thread or not.
Marciel
How do you guys like those bilstien's?
