Bilsteins and zone UCAs
Fanta1500
Albany NY
Hey guys, I need some input. I have a 17 ram 1500 with bilstein 5100 all around. Fronts are @2.8 and have zone UCAs. Just got it aligned and thy can't get the camber or caster on. Camber is above .3° at .6° and caster is above .8 at 5.2° on the right side only. Brand new nothing is bent. Any ideas because I have no clue.
Thanks guys
jljbtm
What are zone utc?
Fanta1500
Fanta1500
Albany NY
What are zone utc?
The upper control arms they sell, got it so I didn't have to worry about oem ball joints possibly popping while running bilsteins at 2.8
jljbtm
Really!?
Fanta1500
Fanta1500
Albany NY
Really!?
Yeah, I read a lot of guys that run at 2.8 have balljoint issues. Rather just play it safe than risk it
jljbtm
Ok ill have to look into those
12sportmc
NC
I had to put the Zone UCAs on with my 2.5 spacers. Actually just ordered new rims tires and bilsteins to swap the spacers with. I would recommend the Zones. I have had them on for just over 6k with no alignment issues and the quality is top notch.
Fanta1500
Fanta1500
Albany NY
Yeah the quality is amazing on them, not sure if the shop I had do alignment if the machine needs to be recalibrated or what but my truck does still favor the left a touch and he said he maxed it out so I'm not sure what the issue is with mine
12sportmc
NC
Have you thought about taking it to another shop? I'm assuming the first shop didn't charge you bc they couldn't get it in specs
Fanta1500
Fanta1500
Albany NY
No they charged me lol, I'm gonna bring it somewhere on Monday or Tuesday probably. I called zone and they are gonna call the shop I went too, to see what is up and I'm going from there. The place I went does numerous vehicles and has been in service for 3 generations also one of the best around Albany NY so I have no clue what's going on. Whether it's the UCA that is bad or if there alignment is messed up. Just disappointing that they can't get it on even though the adjusters have plenty of play to get it aligned
1Popeye
