Body lift questions
Scgirardi
Looking to do the 1.5 zone body lift. I'm occasionally coming across people saying/talking about bumper and hitch relocating???? Is this a concern and what does this mean. #newbie
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
When you do a BL your bumpers and hitch stay stock. Can ruin the looks of a truck.
Raising the bumpers gives back the original look.
Raising a hitch? Not so easy. If even doable without fabrication.
J Rod
Ft. Wayne, IN
With the 1.5", you shouldn't have to mess with the factory hitch. I just had to cut a couple small notches out of the underside of my rear bumper so it would clear the hitch when I raised the bumper. The kit comes with everything necessary to raise the bumpers. The front bumper relocation will require you to drill 2 new holes (1 on each side) in the frame for the upper bolts, the existing holes that were previously used for the upper bolts will then be used for the lower bolts instead. Hope that makes sense.
Wandell
Cummins 6.7
I agree. The Performance Accessories kits come with everything you need.
S
Scgirardi
Ok makes sense thanks guys!
