Bottle jack
Texas
2011 Ram 1500
Without having to have blocks of wood, is there a bottle jack that can raise up a 6in lifted 1500 with 37s?
I found safe jack .com but it would be like 150 bucks. I was curious if there was a cheaper options out there.
Sent from the fetal position using Tapatalk
AustinB
Banned
San Diego, Left Coast
Probably not.
8x8 blocks, or stack some 2x8 pieces bolted together , to use as a base.
Following for a better idea though.
IMO
Mauzz
Are you looking for a trail jack? I have a 10T torin bottle jack and a 12T torin bottle jack hydraulic pneumatic combo that will lift the truck from the axle but if you're on the trail you will still need a wood base plate. If your looking for a frame lift you should probably go with a hi lift.
Beauregard7765
Texas
2011 Ram 1500
I have a hi lift jack but there is no real good "safe" mounting points, I was looking for a bottle jack just for changing a flat on the side of the road and stuff like that.
Beauregard7765
Texas
2011 Ram 1500
I don't have 37s at all right now but eventually will, and plan on having a spare chain down in the bed. I have a 35in spare
corumba
