Can anyone show me there 4" lift on 35's?
Synolimit
Ohio
Colours?....you mean on the pocket flares? I bought the pre-painted Bushwackers.
If you're mulling offsets. If I didn't have the long commute, in hindsight I would have gone with a -24mm offset for a more aggressive stance. I just didn't want to run the risk of throwing a lot of rocks & stuff down the side of the truck on the long commutes with the more aggressive -24mm off stance.
Yes the flares color matched already. Jegs is local but they are black plastic only.
Ok thanks. I think I'll get them, measure, and pick a spacer that'll work. Either 1" or 1.5" so -6 or -19 offset. I too care about chips and stuff.
joeygster
Ancaster, Ontario
So is the consensus among the 4" lift guys that the Bilsteins set at 2.1” leaves with a slight rake & set at 1.4” leaves you level or very close to it?
Right now I’m Bilsteinless, but considering them for the future.
Anyone?
VLG6963
