Chassis Torque Specs
Status
Not open for further replies.
quietpeen
2021 TRX
Hellcat
Chassis Torque Specs - credit goes to brandonjansen for this
(4th Gen RAM)
Shock Absorber Upper Nut --------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -------------------------------------------------------------100 ft lbs
Shock Tower to Frame -------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque------------------------------------------------------ 35 ft lbs
Lower Ball Joint Nut Final Torque ------------------------------------------------------148 ft lbs
Upper Ball Joint Nut -----------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts --------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut------------------------------------------------------------ 200 ft lbs
Upper Control Arm Frame Nuts --------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ----------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket------------------------------------------------------------ 110 ft lbs
Stabilizer Link Stabilizer Bar Nut --------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)------------------------------------------ 110 ft lbs
Stabilizer Bar Nut (Power Wagon) -----------------------------------------------------110 ft lbs
Hub/Bearing Bolts -----------------------------------------------------------------------149 ft lbs
Axle Nut - 132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) -------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) ----------------------------------------------------200 ft lbs
Tie Rod End Nut ---------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -----------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws -------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -----------------------------------------------------170 in lbs
Dynamics Sensor--------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt ----------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle ---------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud--------------------------------------------- 200 in lbs
ABM Mounting Screws --------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts ------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings --------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ----------------------------------------------200 in lbs
Brake Booster Mounting Nuts ------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts ---------------------------------------------------------160 in lbs
Reservoir Retaining Screws ----------------------------------------------------------------6 ft lbs
Caliper Bleed Screws ---------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front -------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear --------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) -----------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) ------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) ----------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) ----------------------190 ft lbs
Junction Block Bolts, Front (1500) -------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) --------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) --------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) --------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) ----------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) -------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -----------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) -----------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -----------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear ------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ------------------------------------------------------7.5 ft lbs
Brake Hose Fitting ------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ---------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) ---------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) ---------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) --------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) ---------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ---------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) -----------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ---------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ----------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) -------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) ------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) ----------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) -------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) -------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ----------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------148 ft lbs
Spare Tire Winch --------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt --------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt -------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts --------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower -------------------------------------------------160 ft lbs
Status
txram956
