cike
- Jul 24, 2017
- 37
- 14
- West Milton Ohio
- 2022
- Hemi 5.7
I traded in my 12 express 2wd reg cab last year for a new left over 2016 crew cab express 4x4. (right after becoming a Grandpa)
This is my first 4x4 (had about 10 2wd's) and even though I don't go off road, I want it to look like a 4 wheel drive.
I am getting ready to order my Bilstein's and Mevotech's so that once I wear out this first set of tires i have what I need.
I am planning on either doing 2.1 or 2.8 plus a 1" rear spacer and either 34 or 35 tires.
Now on to my questions
will the headlights need readjusted? Is it easy to do?
Will the speedometer need reprogrammed?
What are good tires for street only use that still have semi aggressive look to them? Assuming some type of AT?
Is it worth it to do Bilsteins on all 4 corners or is front only all that is needed?
If putting Bilsteins in rear (front set at 2.8) what do you set the rears at?
