Everyone with a 6 inch lift!
RedNBlack
Washington
2012 Crew Cab
Hemi 5.7l
RCX 6" Lift on 35x12.5R20 MT Baja ATZ P3s. No issues with ride quality, love the height, but will be adding Bilsteins at some point to get it more level (personal preference). Seems that the RCX lifts don't seem to actually level anyone's trucks as I have seen quite a few threads on the subject.
Can't compare mileage from stock really as I don't think I ever had any stability prior to the lift, between buying it, adding the tuner and lifting it. I can say I get 15mpg (or more, depending on my driving style) with the lift and 35s and the Bully Dog tuner. I have 3.55 gears. I could feel the difference when I lifted it, but can still get on it... I smoked a silverado the other day!
Thor09
Northern PA
6" RCX, maxed bilsteins, 1.5" rear coil spacers on top of the RCX coil springs. After 2 years and 33,000 miles still rides great.
jpro
Bay Area
6.7L Cummins
I went with BDS 5.5 and because I stayed under 6inchs I kept my warranty on the truck
Do you mind posting details about your wheel and tire setup. I appreciate it. I have an SLT MC and I am diggin the looks of your rig! Thanks in advance.
Ratket
Arizona-
go rcx or bds hands down. I had a 6 inch rcx lift on my last truck, I drove it like I ******* stole it, seriously.. I would pre runn the **** out of it down dirt roads at 80 and crawl, and climb. I could not believe I didn't brake it. then one day, I busted both half shafts, ripped my front diff/axel tube in 3. different place" like 3-6 inch tears". I really torqued the **** out of the front end, the only rough country part I broke was a axel spacer, I called rough country and they sent me all the replacemt parts I needed free of charge, and no Hasle.
PNWHemi
Seattle
I went Fabtech after finding no local places wanted to install the Rough Country. Positive with Fabtech is the replacement springs in the rear as opposed to a spacer. But most on here love the RCX.
Ronin
He mi 6.4
Jpro I'm running 22x10 fuel nutz machined with 37x13.5 nitto mt. The lift is BDS 5.5 with fox2.0 also have dual stabilizer with fox2.0
sbuko213
Hendertucky, NV
6.7 HO
Any body know about the Icon suspension kits? Specifically the stage 4 kit? Is it a waste of money or a good idea? They look pretty sweet and I want to do a pre runner set up on my '14 1500. Or should I just go 4 inch rough country and match up some Foxes with it since I'll be DDing it?
dirtridersr
The icon upper arms are super beefy and use uniballs instead of ball jionts
BLACK2014
TX
2014 express
Had a Lil trouble installing but once I used common sense went pretty smooth. All together have bilsteins maxed out with the RCX 6 in with 1.5in zone bodylift.
Andrew09HEMI
DAMN! Thats got to be close to 10" of lift on that thing, you carry a ladder to get in and out
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
Ladder? It's probably easier to repel down from a helicopter. Lol I'd love a bigger lift but climbing in with my bad back just isn't cost effective for me. My 6 on 35's is enough. The truck looks hot though, I'm not going to lie...
Sent from my SM-N900T using Tapatalk
hemi1282
Arkansas
2016 Ram Tradesman
I'm wantin a lift but don't wanna screw up my warranty so if I stay under 6"s it want be voided? I was looking to get the pro comp 6" lift
hemi1282
Arkansas
2016 Ram Tradesman
there are alot of nice lookin truck in this thread
Birddog
West Palm Beach, FL
That's what I'm wearing. A 6" Pro Comp lift and ES9000's shocks with Pro Comp dual steering stabilizer shocks.
Ronin
He mi 6.4
That's what the service department at my dealership told me as long as its under 6inchs it doesn't void the warranty.
Birddog
West Palm Beach, FL
I'm not a lawyer but I don't think they can void warranty on an entire vehicle because you lifted your truck. I beleive they have to associate the mod with what they aren't going to cover. If your suspension fell apart or your tires wear prematurely it wouldn't be covered because there is a direct connection to what you modified but if your muffler decided to fall off you should still be covered.
