- Apr 28, 2012
- 23,240
- 44,871
- 2010 Hemi Reg Cab 4x4
- Hemi
So I decided to go with the 5100's from the spacer kit I am running. The problem is country roads and my bumper, you can tell there is some binding going on. Minor, but you can tell it isn't right. After researching a 4x4 forum when asked between the two leveling choices, it was 10 to 1 go with the leveling shock with 350 people responding. So I'm am going to see if it helps.
Questions, what is the factory rake? 2.75?
What setting on the 5100 will level my 4x4 Ram?
Is it hard to adjust the setting?
What settings are causing the vibration? Will one off top setting be a wise choice?
