brandonjansen
- Feb 14, 2013
- 1,701
- 1,013
- Abbotsford, BC, Canada
- 2012 Ram 3500 Laramie Limited
- 6.7 Cummins - Tuned and Deleted
So I've been doing some reading and it seems like the 2015 sport black 20" wheels are 18mm offset so if I were to get a zero offset my wheels would technically be pushed out -18mm from where they stand now? This offset **** is confusing
Take a look at the Guide to Leveling & Wheel and Tire Sizing linked in my signature. I explain how offset works in there and there's a few pictures that may help you.
But yes, essentially you have it correct. The stock 20x9's are +19 offset so a 9" wide wheel with a 0 offset will stick out 19mm more than the stock setup. 19mm = 3/4". The conversion is 1=25.4mm
