brandonjansen
- Feb 14, 2013
- 1,701
- 1,012
- Abbotsford, BC, Canada
- 2012 Ram 3500 Laramie Limited
- 6.7 Cummins - Tuned and Deleted
Great looking rig man! I don't even own anything to tow currently so I'll just address the concern in the future if it does become an issue then. I appreciate all of the sound advice. I picked out some 20x9 ProComp wheels. They have a 0 offset which should allow for the 5" of backspacing that Zone says is required for their kit.
Thank you sir!
5" backspacing is the maximum that will work with their kit. You can go with a wider rim and more negative offset if you want to. Personally I would recommend a 20x10 -12 offset. The wider rim and slightly wider stance will look better with the height of the lift.
