Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
zstampe
This is gonna sound stupid but is there any way I could run 37 in tires on my ram WITHOUT having to buy a full blown lift kit, maybe a leveling+body? Just wondering how much lift I would get out of a combo like that if it was maxed ya know. I just bought a leveling kit 3.5" front & 1.25"rear & I wasn't sure how high I could go on the body lift without lifting it way too much & showing the frame not to mention if it's just gonna destroy my front end no matter what. Pretty much is it possible without completely screwing up my truck lol
What leveling kit? That's way too much for the front end without going to a dedicated lift kit.
To answer your questions there's a guy here running bilstein 5100's at 2.8 inches and a rear spacer at 1", he added a body lift and was able to clear 37's.
rubes7202
PLEASANTON, CA
Conclusion
I will stress again that this thread is by no means the end all, be all guide to leveling and wheel and tire sizing. It is simply a thread full of all the information to answer the questions that I see pop up on the forum so often. If you have any suggestions or see any information that should be changed please send me a PM and I will look into it. We will be updating this original post as needed.
For those of you who are new to all of this and are reading through this thread to figure out your set up for your truck please read everything as carefully as possible before posting questions. While I do want this to be an informative post/thread and will encourage good questions to be asked, I also do not want it filled up with questions that have already been answered.
Hey Brandon, great write up. I just leveled my 2015 RAM 1500 with adjustable Bilsteins, as recommended by most. I did this about 6 months ago. I went 2.1 in the front as suggested for leveling. I took pictures today and was wondering they were installed correctly. Rear is higher than front by almost 2". b42a0044084e14b923dd514e54aa4d7f.jpg4615a3e8b586cc16a4a0348683821ff1.jpg2126dfc262b0c0e2bee7d9e98619e67f.jpg
rubes7202
PLEASANTON, CA
Introduction
Hi all! This is a thread that I wrote a couple years ago for another form. I see questions popping up more often than anything relate to leveling and wheel and tire sizing. Although there is a TON of information throughout the forum that would fully answer all the questions that come up, none of it is pulled together in one thread that is easily accessible for everyone to find. I decided to put this thread together to help answer the majority of the questions people will have about leveling their trucks or putting larger wheels and tires on them. This thread is by no means something to outline the only way of doing things. Just because I don’t mention it in this first post doesn’t mean it won’t necessarily work. I will try to include as much information as I can that will be applicable to most people but there are always going to be exceptions.​
Leveling
Determining Your Level Height
A lot of guys will start out their post asking whether or not they need a 2” level or a 2.5” level, or in the base of Bilsteins to set them at 2.1” or 2.8”. While we can give you a pretty good idea on what you need to set them at we cannot be 100% exact. Every truck is built slightly different from the factory; what works on one truck might not necessarily work on another. The best way to determine how much of a level you need is to go out and measure your own truck.
Start with putting your truck on a flat surface (having it on a slope will change the weight distribution and give you inaccurate measurements). Then, running the tape measure from the bottom of your tire straight up through the center of the hub, measure each fender height on the 4 corners of your truck. Write them down labelling each one (LF, RF, LR, RR). From there you will be able to determine what your factory rake is (subtract your front height from your rear height). I would expect most people will see anything between 2.25” and 3.25”. Yes they can be that different, it all depends on the truck.
From there you can determine how much front end lift you will need in order to level your truck. Keep in mind you want to retain AT LEAST 0.5” of rake to avoid looking nose high (bulldogging). But you can have more if you like. This can be achieved by either less lift on the front end or by adding rear coil spacers or blocks to the back end which I will go in to later.​
Leveling Options
There are two different ways you can level the front of an 06+ Ram; Bilstein 5100 adjustable front struts or spacers.
Bilstein 5100 Adjustable Front Struts
The Bilstein 5100 adjustable front struts allow you to raise the front end of your truck by raising the lower spring seat on the strut assembly. There are 5 different height settings, 0 (stock), 0.7”, 1.4”, 2.1”, and 2.8”. By setting the lower spring seat at any of those heights you will gain that much front end lift on your truck.
Bilstein 5100 Product Brochure
There are a number of advantages of running Bilsteins over strut spacers:
•You will improve ride quality by installing the Bilstein shocks on your truck. I find they make the front end slightly stiffer but more controlled in doing so. There’s less bouncing which provides a smoother ride.
•The install is “cleaner” and provides fewer areas for things to come loose or break. Because it is still one strut assembly there are only 3 bolts on the top and one on the bottom unlike spacers where you have 6 bolts on top with weak point where the spacer meets the strut.
•The Bilsteins limit the amount of downward suspension travel which will not allow the control arms to overextend which is hard on CV shaft joints, ball joints, and tie-rod ends.
•The Bilsteins DO NOT limit the amount of upward travel giving you more articulation and flex and less chance of bottoming out.​
I would recommend Bilsteins to 95% of people who want to level their trucks. In my opinion (and many others) they are the best way to level 06+ Rams. They will provide you with the leveling you need in order to clear larger tires and improve the look of your ride plus they can be used with a lift down the road if you plan on going that route.
Bilstein Install
The install of Bilsteins is not much more complex than strut spacers. The disassembly of parts on your truck is exactly the same. The difference is what you do with the strut once you have it removed from the truck. The only difference with the Bilsteins is that you need a spring compressor in order to disassemble the stock strut and then assemble the Bilstein. You should be able to rent spring compressors from most local auto part stores.
Spacers
Leveling spacers are installed on top of your factory strut to raise the front end of your truck. Typically there are two heights that guys will use; 2” and 2.5”. The amount of lift you will get from them is fairly straight forward; it’s whatever the spacer size is listed as. Now keep in mind the spacer itself will not actually measure the same as the lift height it provides. Spacers are used in conjunction with rotating the strut 180 degrees and giving it a steeper angle to achieve the front end lift.
There is only one advantage to using spacers over Bilsteins in my opinion….. cost. Spacers are obviously cheaper than Bilsteins but you have to remember what you are getting in comparison. Yes you will achieve your front end lift but you are also missing out on things and putting your front end at slightly more risk at the same time.
Here are the cons of using spacers rather than Bilsteins:
•You are not replacing the front shocks (struts). Therefore your ride quality will be the same if not worse than stock. The reason it could be worse is because now the strut is being used at a different angle (therefore a different rate) than what it was tuned for. Are most people going to notice that difference? No, I’m just giving you the heads up that it is a possibility.
•Because the spacer is simply installed on top of the factory strut the entire strut assembly is now too long when fully extended. This will put your control arms and CV shafts at steeper angles which can be harder on CV shaft joints, ball joints, and tie-rod ends. Again, not everyone will notice this problem. If you’re only driving your truck on the street and never going somewhere that your suspension will be fully extended you having nothing to worry about.
•Spacers limit the amount of upward suspension travel which can lead to bottoming out​
All that being said, tons of guys will be able to run standard spacers with no issues at all. I ran them on my 1500 for 8 months with no issues whatsoever. However I do regret not buying the Bilsteins from the get-go because I did end up buying them when I lifted it (and was very impressed with them).
As far as I’m concerned, if you’re buying spacers you better be buying them from Hell Bent Steel. They have the best price on them. If you’re looking at getting them from someone else (where you’ll be spending more money) you might as well pony up the little bit of extra cash, do yourself a favor and buy the Bilsteins.
Spacer Install
The install of strut spacers is fairly straight forward. The strut just needs to be removed, the spacer installed on top of it, and then put back in place.​
Links
To be continued on post #2....
One more question. Currently, in running on my 2.1 leveled '15 RAM 1500 the stock 20x9 275/60/20 Goodyear tires. The tire on the front is about a thumb width from the UCA to the inside tire wall (1st pic). I already purchased the Nitto Ridge Grapplers 295/60/20 tires and am wondering if I should get wheel spacers to be safe. What is the thinnest hubcentric wheel spacers I should buy that will be safe and not make my wheels stick out too much. My biggest concern is rubbing on my mevotech UCAs. Should I go with slide in spacers or bolt on? I am thinking bolt on for more stability, but don't want to go more than 1.75". I need help deciding because im confused and don't want to make the wrong decision. Will 3/8" slide on hubcentric spacers work fine?df17307283d8f616af5f5113b21818b8.jpgfe2a9e9e6913dd59d8bad84af179cd88.jpg
Neumie
MN
5.7 8a
Maybe
My opinion is that your new tire may fit...it should be 10mm (1cm) wider on each side...
AFMoulton
Nuevo Mexico
Alright so after reading all 247 posts, I'm still confused as all hell.
Here's what I'm doing with the truck so far. 2016 1500 QC 4x4 Bils 2.8 in front, and Tuftruck Springs in back. Springs raise the back about 2", unloaded.
I want 35x12.5r17 or 18 depending on price of wheels. Is a -12 offset good to keep it from rubbing at all, or do I need to look for something else?
This thread has helped me figure everything out except that! Thanks for all the information
quietpeen
2021 TRX
Hellcat
If it's a 9" wheel you should be good with those tires and -12mm offset. If it's a 10" wheel you make have some minor trimming to do
AFMoulton
Nuevo Mexico
So 10" wheel would require less negative offset to push the wheel out from the hub? Correct?
daveray9
Take a photo of where the spring rests on the bilstein and post it.. might have installed it wrong..
Tmemz
hey quick question. am I right to think that I should be able to get away with just getting 5100s for just the front on my truck that is a 14 with only 15k miles on it and not have to worry about uca's
Sent from my SAMSUNG-SM-G920A using Tapatalk
moparpeetie
south central PA
wheels
ok so I'm going with Fuel Coupler... I have Bils at 2.8 and tgc 3/4 rear spacers. I'm thinking 295 65 20 toyo at II or 35x12.50x20 cooper st maxx. Wheels are only available in -12 0r -25... Question is how big of a spacer, if any, will i have to run to prevent rubbing upper control arms. I can get wheel 20x9 with 1, -12 or -25. I really want to be as flush as possible., but a stock flare wouldn't be bad. Appreciate any help!! Thanks!!!
quietpeen
2021 TRX
Hellcat
20x9 +1 is what you will want and you won't need and wheel spacers to clear the uca's
Sportznut
2019 Laramie
If you set them at 2.1.
Many have set at 2.8 and no UCA issues but not everyone.
2.1 or less seems to be the "safe" bet.
AFMoulton
Nuevo Mexico
Alright last dumb question, lol. I have my Bils set at 2.8 and I have the TufTruck Springs in the rear. Looking at 17x8.5 -12 offset wheel and I want to put 315/70r17's on them will I need to or should I have to trim anything?
