GabAlmighty
Haven't found much info for this particular generation truck with no lift... Anyone know if a 305/70R17 will fit on a stock truck with a lower offset rim?
What would you all recommend for a 2017 crew cab 4x4? I would like a slight level while keeping a rake, and will be keeping the stock tires and rims. My truck has a serious rake at the moment, but I’d like to keep the ride as smooth as possible.
ok thanksnot from what I've read. You should be GTG
I have a 2010 QC Bighorn, and am thinking of doing a similar setup with stock 20s. Do you think that the rubbing would still be happening with 33s?I posted this info elsewhere but I doubt anyone has seen it. I have a level front and stock 20’s on a 2010 with 1” spacers. I went with 35x12.5x20 firestone mt/2’s. Rides awesome a small amount of rubbing at full lock but it is purely on my plastic inner fender. Look is a little stuffed but I work out of the truck so reaching over the side is kinda important.
Amazingly smooth and quiet tire. About as loud as my terra grappler g2’s on my jeep. Just got em so I’m sure they will get a little louder but very impressed.
Sent from my Nexus 6P using Tapatalk
If you're wanting the look imaged and 3"-4" past the body stance, a 22x12 -44 will get you there. It's up to you, but you cant fit that in on level with 0 trimming. Hell, you can fit that stock height with no trimming.View attachment 118320 I’m new here and have a question. I’ve got a 2010 1500 quad cab that’s been lowered with a 2/4 drop on 24’s. I’m now wanting to go the other way. I need to know what offset I’ll need to go with in order to get the wheels 3-4 inches past the fender well if I’m using a 22 inch rim. I spoke with someone at a shop and they suggested a Rough Country 6 inch lift and going with a 22x14 with a -76 offset. This is the look I’m trying to achieve. Also would I need to go with a 6 inch lift or would 4 be enough. Can anyone tell just by looking what this truck has?
