Has anyone installed 1.5 inch lift Icon rear coil
L.M._Rog
I need a little lift in the rear of my truck after installing my Bils. I'd like to avoid the spacers if possible and can't find much on the Icon 1.5 lift coils so thought I'd ask.
Sent from my SM-G950U using Tapatalk
Ravjay12
I'm installing those in a couple of days. I'm going to set my Bils at 2.8 with Zone UCA's and rear Icon springs and rear Bils. I'm really excited!
L
L.M._Rog
Please let me know if you get an actual 1.5 out of them. I would like to get at least an inch considering I have a fiberglass topper as well.
WiSH2oo0
MN
2017 1500 Express 4wd RCSB
You're going to do have to get a hub to fender measurement before and after. Since our trucks rake very from truck to truck and drivers side to passenger side. I'm interested in the results as well because the Superlift 2" rear coils lifted my RCSB 3.5" passenger side and 3.75" driver side in the rear.
Ravjay12
I'll definitely let you know with photos. I'm assuming it's going to settle some.
Ravjay12
I got everything installed today. Zone UCAs, bilsteins at 2.8, and Icon springs. It is actually at 1.5" of lift when they were done. I'm interested to see if it will settle some. I suspect it will. I'll post up pictures when I get her cleaned.
WiSH2oo0
MN
What was your rake at before the 1.5" rear coils?
Ravjay12
I think that it provided the stance I'm going for. How's the ride?
The ride is great! Better than stock springs for sure. I also have the Bilsteins back there so that could be a factor also.
JB1
Houston, Texas
looks nice, bet it rides great, the bils are a nice improvement in ride quality
Ravjay12
Night and day difference! Even at 2.8” I guess my stock shocks were toast.
Motogirlzero
5.7 4x4
Ravjay12 . your truck looks great! what size tires are you running? and do you happen to know what the overall height of your truck is now? i'm looking to do same set up, but only have 7ft clearance in parking garage for work.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
bils at 2.8 will still get you in the garage. I've got that same concern, but I'll be adding a zone 1.5" body lift before I'm done. Adding rear coils shouldn't change front height at all
Motogirlzero
5.7 4x4
Thank you i am planing to do the whole set up, Bils front and rear, fronts at 2.8 with the icon +1.5" rear springs and UCA upgrade. my last ram i only installed the fronts at 2.1 the rear i left stock , just to get it level. why i was wondering over all total height before i commit to the 2.8" front set up
shadowhawk
Southeast WI
There's a Zone 1.5 lift thread going, too.. People don't usually post the total height except they do fit under a 7' garage door opening. I'll link to the thread
LVnight1500
What UCA's you plan on installing?
RamRoy
Crestview, Florida
I have a 6" RC lift. A while back I had Bilstiens put up front and it is a bit nose high. Hard to get a true measurement because I can't find a good level area to park on. Anyway, seems the front is .75 to 1.25" higher.
I have the ICON 1.5" springs sitting at home ready to install.
