Lets see those 1500's on 37's...I'm getting the itch to go bigger
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
So I went from the stock suspension to a Ground Force 2/3 lowering kit, to Bilsteins and 35's, to the Icon stage 5 suspension with 35's, and now looking to go 6"+ with 37's. I've looked through the lifted truck thread that's 400 pages long :roflsquared:, but many of the pics in there dont share details on lift sizing, wheel specs, ect...
I would prefer to stay with a 17" or 18" wheel, but I'm open to 20" max. Lets see what you guys have.
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Down there bud :favorites13:
6"
37x12.5R20
20x12 -44
Looks good. What front setup are you running? 3" or 5" rear coils? And does it rub with that low offset?
I am trying to keep the wheels tucked in the fender the best I can, so I' leaning more towards an 18x9 wheel with 5" BS 0MM Offset.
Rzrman328
The treeline
OE coils. No bils up front...it rubbed without modification.
0 offset may stick out slightly...are u running flares?
deangtp
Superlift 6/5 bilsteins at 2.8. 37-12.5-20 Mickey atz p3. 20X9 -12 RBP 96R
WilliamS
Tampa FL
New A/T traction winner right there! Just kidding, those are MT's
Im still torn on 37's and 35's. I can go 35's now, and even if I go bigger lift they look fine. Where if I go 37's I have to get the lift first. Ugh. Good luck OP
WilliamS
Tampa FL
6.7CumminsDrvr
The Dude abides………
Georgia
Ha! I keep trying to talk myself off the same ledge........sure looks like I could stuff 37's on my truck with a little tweaking!
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I went ahead and ordered everything yesterday. 18x9 Fuel Anza wheels with 5" BS and Toyo MT 37x13.50x18's, and the BDS standard kit with 5" rear coils, Fox 2.0 rear shocks, and Bilstein struts up front. Should have everything here next week.
JB1
Houston, Texas
I'm really looking forward to seeing this and getting your review of that setup. I'm on the fence about going with this same setup so you will help me decide. :favorites13:
EDIT >>> Are you going to replace/upgrade the UCA's with mevotechs or the ZONE's etc?
Williams3803
2012 Laramie Longhorn 4x4
Zone 6 inch lift (5 inch spring), bilsteins at max up front, fox shocks on rear, 2 inch wheel spacers, factory 20x9 wheels, Toyota 37x12.5 /20 tires. No rubbing at all. So far it rides well and no problems.
WilliamS
Tampa FL
Still my favorite looking truck on here. Just looks stock!
R.L.K.
Bristol , Tn.
Looks like 10" lift , 37" tires and 14" wide wheels -44. ?
