Jwithing
Nice, what's the wheel size and offset?
Any trimming required?
Mine are 20's. Not sure on the offset, bought the truck with it already lifted. That said, I don't see any trimming done and there's no rubbing either.
My finished product...
Is that an aluminum driveshaft? Why the hell does mine have rusty steel ones?
Zone 6 inch lift (5 inch spring), bilsteins at max up front, fox shocks on rear, 2 inch wheel spacers, factory 20x9 wheels, Toyota 37x12.5 /20 tires. No rubbing at all. So far it rides well and no problems.
Fuel Anza 18x9 1mm 5" BS (had to also use a 1/4" wheel spacer due to the width of the tire causing it to barely touch the spindle)
Toyo MT 37x13.50/18
No trimming needed
Fenders 46" Front and 46.5" Rear
Bilsteins are at 2.8"
Looks great man. Perfect sidewall height to lift ratio.My finished product...
So I went from the stock suspension to a Ground Force 2/3 lowering kit, to Bilsteins and 35's, to the Icon stage 5 suspension with 35's, and now looking to go 6"+ with 37's. I've looked through the lifted truck thread that's 400 pages long , but many of the pics in there dont share details on lift sizing, wheel specs, ect...
I would prefer to stay with a 17" or 18" wheel, but I'm open to 20" max. Lets see what you guys have.
So what about gears ? No one seems to concerned with that? I think the 37s look badass but it is a big and heavy tire. What gears you guys have ? Did you guys upgrade the gears or just running on stock? If running stock how bad is it ? I’m assuming most of you just have the 3.92?
Tire weight can be an issue. One reason I went with the Yokohama Geolandar 37’s is that they only weigh 76.7 lbs, that’s only 3lbs heavier than the 35/12.50R20 Nitto Ridge Grappler that’s so popular on here so that’s a non issue with me. I do have the 3.92 with LSD and 8spd trans and my truck has plenty of power and rides smooth.
That is a beautiful truck!!
These tires were just released in 07/2017, I have only had them for 1500 miles so no long term review yet but so far so good. They ride great in the rain and are very stable at all speeds. I really like them a lot.
O okay wasn’t sure how many miles ya had on it but the other info is appreciated!
