Leveled on 37's????
DirtyGoat
I just put a 3" leveling kit on my 13 ram 1500 Big Horn with 35" Toyos. I clear the tires completely but I don't like all the space in between the tire and fender. So to my question, is anyone running a leveled truck with 37" tires? If you do you scrub?
Also has anyone attempted a 6" lift and 40s?
Rzrman328
The treeline
Not sure I've seen just leveled and 37's. Pretty sure it'll rub. I think very few have ever put 37's with a 4".
Plus 37's with a level wouldn't look very good....IMO. It'd be super stuffed. There has been some guys who have done 6" lifts that could've thrown 40's on but most would not reccomend such a big tire for a 1500.
trikeffex
Hammond,La
2013 sport ram
Could you post a pic of your truck? I've been debating between 33's and 35's on my leveled Ram.
dan1911
Fairbanks, Alaska
Leveled with 34s
Kinda middle of the road between those two sizes and love it. I probably wouldn't go smaller so I'd pass on 33s for sure. Our trucks are a lot of truck and deserve a lot of rubber [emoji12]
Sent via telepathy
Schmittj22
New Jersey
Im interested in knowing-
I am at 4 inch zone lift with 2.1 bilsteins.
Looking at 37x12.5s
flammablehemi
Cummins
I think those look perfect. I can't say for sure if you will have rub on 37's, but my guess is you will. I just put 295/65/20's on mine with only (guessing 2") level on mine, and they are pretty close in the front.
Jwithing
STL
37x13.5x20 w/ 6" BDS lift
trikeffex
Hammond,La
2013 sport ram
Leveled with 34s
Sent via telepathy
That looks good man. I may look into a 34" Size. How do you like those tires. I've looked at those along with quite a few others.
dan1911
Fairbanks, Alaska
I don't have enough good things to say about these tires. Have a decent treadwear warranty for their 10 ply. Weekend off roading but definitely not a crazy swamp tire, and quite on the highway. Have never been stuck or stranded but drove on the Dalton hwy in Alaska (look it up if you're not familiar, it's crazy!) with zero punctures or ANY issue. This is my second set and will likely get another.
Pic is of bilsteins set at 2.1 with a 1 inch TGC rear spacer, 34x11.50 Toyo AT2 extremes
Sent via telepathy
Synolimit
Ohio
What did you do for 3"? I have 5100's at 2.1" and 0.75" rear spacer on a true 35.12" 295/65/20 tire. I want 37's now which are 1.42" taller. Should fit as its only 0.71" on each side.
