RAMblin1217
- Feb 16, 2016
- 518
- 284
- 2014
- Hemi 5.7
Would it make a difference that I'm getting the nitro shocks? I was told they were better. I think I will do 6 in front and 3 in back.
Those will be the rears only, so your front will be factory stock, meaning you'll definitely want the Bilsteins to level it out.
As for gear ratio, you more than likely have the default factory crappy ones unless you asked for the upgrade. If you bought it used, it's definitely the crappy gearing since hardly anyone with upgraded axles/gears sells their truck very quickly. Look up what the options were for your year, make, model and realize it's something like 3.21 or possibly 3.55. You'll want something like 4.56 or 4.88 for 37" tires though. Replacing Themis costly and sometimes means buying new axles if stuff is welded solid. Hopefully you're lucky and just need ring and pinion, but still not cheap.
