leveling kit + 6 " lift, can I fit 37's?
Jhub
BC, Canada
I have a 2011 outdoorsman, I bought with a leveling kit already installed. I was wondering if I could fit 37's after I install a 6 inch lift. Or would I have to install bilsteins and rear coil spacers also? Any ideas??
Thanks!
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Might be kind of tight, depends on your wheels or if you use spacers. I'm 99% sure you could with bilsteins, but good luck finding them! Out of stock everywhere :(
MiRamDriver
It seriously depends on the width of the tire as well as what the wheel width/offset is. I can assure you that you'll need to install Bilstens if you want any suspension articulation.
Cormier3288
Upstate NY
2011 Outdoorsman
5.7-liter HEMI
Posting to stay tuned to info. I have a 2011 Outdoorsman Reg Cab. I never see outdoorsmans running around.
JoshikusIII
Reno, NV
Thanks!
I'd consider a 2"(or 3" if willing) body lift and 4" suspension combo if you seek tire clearance. And yes wheel offset will play a major role. You can only get so far with pure suspension lift, eventually that body will get in the way when it comes to tires. Luckily these Rams have giant wheelwells to start.
012RAMbo
West Monroe, La
Like shawn226 said, the only leveling kit you can add to a suspension lift is with adjustable struts. Such as bilsteins, pro comp ect. If you have a puck style spacer up front, you will have to scrap that with a lift..
klaronde
Hawaii
You could do it with the Rancho quiklift as well. No spacer used with it.
VLG6963
