bigben5054
- May 22, 2014
- 8
- 7
- 2014
- Hemi 5.7
Hey all. I bought the 2.5" leveling kit from Rough Country for my 2014 1500 and tried to install it over the weekend. All went well until it came time to compress the coil spring and remove the top strut nut. The Rough County instructions in all caps and bold text warn not to use an impact gun on this nut. Well, without some sort of special fancy tool that I don't have, there was not a chance in h*ll that nut was coming off. So I Googled it and far and away the most information out there says use an impact. So I gave it a try - but it failed to work as well. I was careful to not just sit and spin the nut (and shaft) too much, but I probably did about 20 spins at a moderate speed. Finally I just gave up. Did a little reading and found that many leveling kits (like Hell Bent Steel) do not require the coil spring and strut to be taken apart - they just sit on top of the strut. Well, I ordered the HBS and will return the Rough Country. Meanwhile, I have to put the truck back together, which seemed to go fine. Everything nice and tight, and I made sure the coil spring ends were seated correctly. Problem is now I have a bit of new noise under that side. A bit clunkier, perhaps a rattle type noise. So give it to me straight - did I ruin the strut? Assuming the nut never moved on the shaft, did spinning loosen something internally or what might be going on here? Thanks in advance.
