Leveling suggestions.
ikebats03
Have a 2009 Ram 1500 5.7L. Wanted to level it, and have about a 2.5-3" rake. After looking into a couple things, I was planning on running a set of 2.5" Front lift coils from MaxTrac; MaxTrac 872171B with the Beilstein shocks. Also, was going to put the Beilstein shocks on the back as well. Any input from you guys? Anything I should do differently or look into? I've heard too many stories of coil spacers completely screwing trucks up, so I didn't wanna go that route. Drop some knowledge bombs on me. Thanks in advance y'all.
Hawkman
South Carolina
If you are just going to level, just go with the Bilsteins in the front, set at 2.1 or 2.8, your preference. That will accomplish the level. If you want to lift it, then look at the additional springs and lifting elements for the rear. JMHO
Welcome to the forum.
