Musclemckeester
The Kore stuff is good stuff just usually priced fairly high, but that doesn't seem bad at all. Did you notice it says at the bottom you'll need aftermarket wheels 17x8 with 4.5" of backspacing?
helloo again guys I found this lift kit it looks great , with a high price tag but I think its the only way to go tell me what you guys think
KORE Prerunner Series for 2009-Current Ram 1500
Lmao I don't think he need the advice anymore! Look at the date of his postThat's about the same price wise as you would be getting with a 4" drop bracket kit. If you're looking at doing a 3 inch suspension lift (with coilovers and such) be prepared to drop big money because they are generally higher performance mid to long travel kits. Also Kore does not really make anything anymore. Look into Icon, they make a very similar kit with coilovers.
If you have the rancho quick lift or bilstein struts than no. If you have a spacer level than yes you doI am installing a 6 inch rcx lift this weekend.
Do I need to remove the leveling kit?
hey guys
I have recently installed a 3.5" level kit ( ebay special) on a 2013 dodge ram 1500 was not easy to install...... had to put extended brake lines we got it up and running with a set of 35' m/t's but there is some seroius pot hole wobble is this kit safe???
