Lifted 4th Gen Pics - Show Em Off!
csm64
Florida
Love em. I was looking at the icons and Fox 2.5s but definitely happy with the bils. Paid a little more to have them preassembled and set at 2.8 but wanted to make sure they were set up right before installing.
Dan Topp
Jefferson Wisconsin
Unfortunately the 265/70 17s Michelins are barely 4 months old Handles ok. Thought I should show this. Really bottomed out with dirt for wifey,it’s gonna need helpers or something.234E7012-B62B-4C8B-A49F-C40E0AB04C30.jpeg0BCE4A33-D347-4299-9AD2-E142DAFB29E1.jpeg
MoparFin
U. S. Navy Vet - AS1
PA
Added RC 3” loaded struts to the front instead of the 2 1/2” MotoFab spacers I had. Ride is WAY better. Forgot to take measurements before like a dummy. Front is sitting at 42” to the ground. Back is at 42 1/2” with 2” MotoFab spacers I installed a while ago. If I remember right, there was about a 2” difference before only driven about 50 miles, if that. EF538320-B520-44A8-9837-FD2DB47CF397.jpegDEDFED6D-09A5-42A4-B0D6-562FFDDE4D4D.jpeg
minotto
italy
Aggiunti montanti caricati RC da 3 "nella parte anteriore invece dei distanziali MotoFab da 2 1/2" che avevo. Ride è MOLTO meglio. Ho dimenticato di prendere le misure prima come un manichino. La parte anteriore è seduta a 42 pollici da terra. La parte posteriore è a 42 1/2 "con distanziali MotoFab da 2" che ho installato tempo fa. Se ricordo bene, c'era una differenza di circa 2 pollici prima di guidare solo per circa 50 miglia, se quello. View attachment 518325View attachment 518326
Ciao , puoi scrivermi il nome esatto o il codice prodotto di questi montanti 3" rc? hai cambiato anche i braccetti?
Thanks
MoparFin
PA
Thanks
Rough country 3” loaded struts. Upper Control arms are Mevotech TTX.
minotto
italy
Do the mevotech ttx have the same angle as the oem arms or are they made for 2 to 3 inch lifts?
I found them on amazon but I don't understand if the price is for 1 arm only or for the pair
These rough country 3" shock absorbers use the same criterion to create the lift of the bilsten 5100 with adjustable ring ?
What changes on a technical level?
Are Rc shock absorbers longer than Bilsteins or do they create lift only with the supplied spring?
MoparFin
PA
UCAs are each and are stock geometry. When I got it aligned after 2 1/2” lift, they got it close. I will probably get Freedom OffRroad UCA next.
RC struts are longer. They are not adjustable like the bils.
minotto
italy
Many people suggest me to replace stock ucas with zone lift ucas or bds from lift between 2 and 3"
Another question : for rear lift its better put a spacer on stock spring or replace it with eibach / bilstein or tuf spring series vt from 1 to 2" lift ?
outdoorsman014
Hey everyone. this is my 2014 outdoorsman ... has the 2.5" Elka front / rear suspension with 1.5" taller coils. Zone UCAs and a bunch of other goodies! currrently on 35/12.5/17... hoping to stuff 37s under soon but it might be tight haha
