lifting AWD
mihokz
Madill, ok
Ok, so i am wanting to lift or at least level my truck. I am really wanting a 4in lift, but a i can live with just a leveling kit. I notice that some lift kits say they do not recommend installing on vehicles with AWD. if i level i will do with the Bilsteins.
I emailed rancho and this is their response "Unfortunately, no due to the front driveshaft rotating at all times on this vehicle, the angle that the driveshaft will be at with a leveling or lift kit installed could potentially create vibration concerns at higher speeds. We apologize for any frustration or inconvenience that this may have caused."
i spoke with a shop near me and they were not aware of this issue and did not think that the AWD would make a difference. is there any hope of my dreams coming true?
Juvenator93
98f317edfef4c0677ad161f1214fcdfc.jpgaf3ce83fd27549db6bb206e868ad8bb7.jpgd1a54e1f30ebf104e15c67a0d0ae285d.jpg I never had problems with my 2012 1500 with any amount of lift
Csanders1992
Auto 4wd and AWD are two different things. As far as I know they don't any Rams AWD so I'm assuming yours if 4wd with the auto option. If that's the case, you will have no issues with a lift kit
Juvenator93
The 4WD Auto works like AWD.
Csanders1992
AWD is power to all 4 wheels all the time. Auto is 2wd until the computer senses slipping. You can't turn off AWD on most vehicles but you can turn off auto 4wd
6.7CumminsDrvr
The Dude abides………
Georgia
Lift it dude!!!!!!! Pay no attention to the AWD nonsense, truck will run just fine.
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
4 auto is not all wheel drive brother. :)
4 auto is a feature that allows a driver to drive their truck on dry pavement in 4wd. The computer senses when the 4wd should kick in (hence 4 auto) and will usual take place when the rear tires lose traction.
I usually use this feature during a heavy rain or if I suspect possible black ice on a back road I frequent in winter.
Lift your truck brother and don't worry about your components. tons of people run bilsteins set a 2.1 on their truck, including me, without issues :). If you lift, check out Zone Suspension, very popular for our trucks and on this forum.
Do a forum search for the "everything bilstein mega thread" if you decide Bilsteins.
whatTHEmilone
Grand Forks, ND
2013 Ram 1500 Express 4x4
Hemi 5.7l
I'm pretty sure that RAM doesn't make an AWD truck. You can get 4WD or 2WD.
Blue Man
St Marys Ga
I know i am late to the party, i lost my invitation. My avatar is my 2004 ram 1500 AWD, leveled with stock torsion keys 20x10 rims with 35x12.5x20 AMP MT's. I am wondering if anyone has successfully put a 4 or 6 inch kit on an AWD without issues and has had it for a while? If so, what kit did you get? Thx
Ratket
Arizona-
Um... two many wrongs blue man .. you just broke the 4th gen section-
It’s a damn unicorn!!
So if ur ram is 2nd or 3rd gen you will have better luck posting in that section. From the little research I did in the last 3 minutes “ google is my friend” you can’t lift that truck.. the one that is actually AWD. Congratulations .. you found a unicorn lol. I had no clue Ram ever made a “AWD truck” - Learn something new every day...
To the O.P what year is your truck??
