dhows31
I'm getting a 4in zone lift and bilstein 5100s. If I use the bilsteins at a lifted position, would I still use the strut spacer that comes with the lift kit?
I run the zone 4 inch lift and was thinking of doing the same shocks to get the 2 inch rake out If I take off the coil spacer where do I set the new shocks at the spacer gives you 1 inch unless I'm wrong i'm also running 35's
I thought I read somewhere where you have to remove the preload spacer if you use those shocks
On a 6" lift, yes as they use a preload spacer. A 4" lift doesn't use a preload spacer as stated above.
Is the preload spacer on the 6" kits only for the 13 and up model years?
Zone uses them on all 4th gen 6" kits.
I noticed rough country does on the newer rams but I dont recall having a preload spacer on my 2009 with a rcx. Any idea why on the newer trucks that is?
