Little Lift Question
Hemi Ram12
I have a 2012 Ram 1500 ST 2wd and i am wanting to lift my truck with a 3 inch supreme suspension spacer kit in the front and a 2 inch supreme suspension spacer kit for the back. with those two kits what size tires do you think is possible to fit. the measurements for the truck would go from 35 1/2 and 39 to 38 1/2 to 41 inches. I would be running stock rims on it witch is 20x9. Also would i need to get longer front brake lines or would the stock lines be okay.
